abr33 Posted September 12, 2012 Share Posted September 12, 2012 Hi all, I fitted my new large 2 piece tailshaft, along with 2nd hand 4.11 diff, I opened diff and cleaned etc, see shaft in the 'what tailshaft do you run' thread. I have a coppermix single clutch which gives gear noises at low revs as its got no damper, but at 120 it feels like being on the ripple things on the freeway, its terrible! The diff felt good and appeared ok when I cleaned it, but it got super hot (70 degrees ish) in under 10 kms driving. Please help I have a trackday in a week! Link to comment https://www.sau.com.au/forums/topic/409144-big-vibrations-issues/ Share on other sites More sharing options...
The Dan Posted September 12, 2012 Share Posted September 12, 2012 Hi all, I fitted my new large 2 piece tailshaft, along with 2nd hand 4.11 diff, I opened diff and cleaned etc, see shaft in the 'what tailshaft do you run' thread. I have a coppermix single clutch which gives gear noises at low revs as its got no damper, but at 120 it feels like being on the ripple things on the freeway, its terrible! The diff felt good and appeared ok when I cleaned it, but it got super hot (70 degrees ish) in under 10 kms driving. Please help I have a trackday in a week! The people who made it need to balance it again or possibly the length has been measured incorrectly? Also make sure your centre bearing is in its natural position. Link to comment https://www.sau.com.au/forums/topic/409144-big-vibrations-issues/#findComment-6530017 Share on other sites More sharing options...
GTSBoy Posted September 12, 2012 Share Posted September 12, 2012 And make sure the universals are set up correctly. Possibly doesn't matter so much on a 2 piece, but it probably still does. Link to comment https://www.sau.com.au/forums/topic/409144-big-vibrations-issues/#findComment-6530034 Share on other sites More sharing options...
WMDC35 Posted September 12, 2012 Share Posted September 12, 2012 /\ on the 2 piece the uni's need to be lined up, did it come bolted together?, still if the diff is getting hot may be binding somwhere?, if you need to get to the track maybe just get another diff, did you have the old tailshaft to try as a comparason? Link to comment https://www.sau.com.au/forums/topic/409144-big-vibrations-issues/#findComment-6530169 Share on other sites More sharing options...
abr33 Posted September 12, 2012 Author Share Posted September 12, 2012 No, my shaft was the donor for centre spigot and sliding spline, It was bolted together when they balanced it, and it was balanced to some crazy tolerance. And uni's were setup to within a thou of perfect. The centre bearing could be lowered 5mm to get shaft perfectly straight, but that shouldnt affect it. Its very bizzare, I expected gearbox noises to resonate through it, but not a death vibe. How could anything in the diff be causing this and how could it get so hot? Its never been shimmed either.. I have my 4.36 diff which is lazy but will get me out of trouble. I will get a genuine good condition shaft sent out today incase it all turns to shit. This is pretty sad though... Link to comment https://www.sau.com.au/forums/topic/409144-big-vibrations-issues/#findComment-6530178 Share on other sites More sharing options...
34GeeTeeTee Posted September 12, 2012 Share Posted September 12, 2012 How do you mean "lazy"? Also, interesting on the gearbox noise... How much noise are you getting? Is it just a light sound? (sorry I know it doesn't help your problem but it's related to a similar convo I had this week) Link to comment https://www.sau.com.au/forums/topic/409144-big-vibrations-issues/#findComment-6530217 Share on other sites More sharing options...
WMDC35 Posted September 12, 2012 Share Posted September 12, 2012 it is unusual for a diff to cause that much vibration, if it wasn't getting hot i'd be pretty much only looking at the shaft, diff must be binding or something, hopefully trying the other shaft will shed some light on it Link to comment https://www.sau.com.au/forums/topic/409144-big-vibrations-issues/#findComment-6530246 Share on other sites More sharing options...
The Dan Posted September 13, 2012 Share Posted September 13, 2012 Is it possible the shaft was damaged in transit? Even a small dent or knock will put the out of balance Link to comment https://www.sau.com.au/forums/topic/409144-big-vibrations-issues/#findComment-6530722 Share on other sites More sharing options...
abr33 Posted September 13, 2012 Author Share Posted September 13, 2012 It had been dropped in transit, small scratch mark on flange. But iv narrowed it down. Old diff back in, and its between 115 and 130 kmh. , its doing my head in, diff and box within well under 1 degree. Is a harmonic imbalance plausible? Link to comment https://www.sau.com.au/forums/topic/409144-big-vibrations-issues/#findComment-6531371 Share on other sites More sharing options...
The Dan Posted September 13, 2012 Share Posted September 13, 2012 It's your tailshaft. take it back to them personally and have it rechecked for imbalance while you wait Link to comment https://www.sau.com.au/forums/topic/409144-big-vibrations-issues/#findComment-6531382 Share on other sites More sharing options...
abr33 Posted September 13, 2012 Author Share Posted September 13, 2012 Its 2 hours each way to them, im going to try fitting the factory rear half, ans see if that fixes it Link to comment https://www.sau.com.au/forums/topic/409144-big-vibrations-issues/#findComment-6531440 Share on other sites More sharing options...
WMDC35 Posted September 13, 2012 Share Posted September 13, 2012 as above, it's got to be the shaft, i'm sure they won't mind checking it Link to comment https://www.sau.com.au/forums/topic/409144-big-vibrations-issues/#findComment-6531442 Share on other sites More sharing options...
WMDC35 Posted September 13, 2012 Share Posted September 13, 2012 Its 2 hours each way to them, im going to try fitting the factory rear half, ans see if that fixes it the 2 piece is balanced together so unlikely to improve anything Link to comment https://www.sau.com.au/forums/topic/409144-big-vibrations-issues/#findComment-6531445 Share on other sites More sharing options...
abr33 Posted September 13, 2012 Author Share Posted September 13, 2012 And obviously ill get it sorted. Im thinking some sort of damper is needed Link to comment https://www.sau.com.au/forums/topic/409144-big-vibrations-issues/#findComment-6531446 Share on other sites More sharing options...
abr33 Posted September 13, 2012 Author Share Posted September 13, 2012 the 2 piece is balanced together so unlikely to improve anything But the factory rear is rubber driven Link to comment https://www.sau.com.au/forums/topic/409144-big-vibrations-issues/#findComment-6531452 Share on other sites More sharing options...
WMDC35 Posted September 13, 2012 Share Posted September 13, 2012 ok, maybe just put the factory one in complete, should tell the story Link to comment https://www.sau.com.au/forums/topic/409144-big-vibrations-issues/#findComment-6531455 Share on other sites More sharing options...
abr33 Posted September 13, 2012 Author Share Posted September 13, 2012 I only have rear half lol. Factory front in transit Link to comment https://www.sau.com.au/forums/topic/409144-big-vibrations-issues/#findComment-6531487 Share on other sites More sharing options...
abr33 Posted September 14, 2012 Author Share Posted September 14, 2012 After checking everything yet again, all angles are perfect, and the vibration is worse at diff end. I was told not a good idea to undo centre loint and fit factory rear half as its not balanced together, but they should both be balanced anyway so ill have to try it. Anyone got any further experience/input? Link to comment https://www.sau.com.au/forums/topic/409144-big-vibrations-issues/#findComment-6533232 Share on other sites More sharing options...
abr33 Posted September 15, 2012 Author Share Posted September 15, 2012 I put factory rear half on, the vibration is almost gone. I think I can still feel the slightest bit still but not sure. Definately a balance issue with the shaft. Link to comment https://www.sau.com.au/forums/topic/409144-big-vibrations-issues/#findComment-6534554 Share on other sites More sharing options...
abr33 Posted October 4, 2012 Author Share Posted October 4, 2012 So I had the shaft rebalanced again. This time far more accurately than before. Been running stock shaft, no issues at all. Put on new big one again, same vibration! Anyone got further ideas before I loose the plot?? Link to comment https://www.sau.com.au/forums/topic/409144-big-vibrations-issues/#findComment-6563579 Share on other sites More sharing options...
