Time for another large Skylines Australia cruise?
Hey guys n galz
XRSIST remided me of something on ICQ, we haven't had a good SKYLINES AUSTRALIA meetup in a while! We've got weekly meets and stuff but nothing major, like a BBQ cruise. Anyone got any ideas for dates/destination, lets say 2-3 weeks away?
ryan
a Sunday, under roseville bridge at middle harbour.... awesome BBQ areas.... good parking as long as people arrive on time.... wide open space on the shores of middle harbour...
Organised a joint Impact autosports / silvia nsw BBQ there before
Sounds good....
its normally a great day down there.... if someone works on the cruise organisation I will arrange for the BBQ and cruise to be covered by HPI :)
We will work something out prolly best to start with a date
