i still need this gearbox my car is for sale but i have to replace the box first cos the heavy duty clutch has done its job on the synchros the clutch place told me it mite go through a box and that it has done
help me with a skyline box that fits r32 gtst
https://www.sau.com.au/forums/topic/40922-gearbox/#findComment-862618
