So the car's now gone and i'm left with a bunch of stuff to get rid of!
Old post is here - http://www.skylinesa...point-cook-vic/
This is what's left - i've got nothing else apart from what's here! I've also got a box full of nuts and bolts of all sorts so if you're looking for that kind of thing, feel free to ask, or make an offer on the lot!
Mirror triangle cover thing - $10
rear wiper motor $20
drum brakes (in bits and pieces) $10 for both
Rotors x 4 $70
Pod filter $10
Centre dome light (without cover) $5
front reading lights $10
stock crossover pipe including BOV $20
HICAS computer bits $30
ac pipes $10
blower fan $20
bonnet lining $10
boot hinges and torsion bars $30
bonnet lining $10
boot rear trim light cover $10
brake booster $20
brake pedal $10
engine mounts x 2 $20
centre console hand brake leather $10
centre console front trim $10
cluster surround $20
door sill trims x 2 $10
driver's side kick panel $10
dump pipe (stock) $10
AC evaporator $10
front pipe (stock) $10
fuel tank blanket $0.25
fuel tank strap $0.25
hicas steering rack $30
interior wiring (includes wiring that goes into the boot) $30
jack stands x 4 (only used once! :) $30
passenger side a pillar trim $10
passenger rear arm rest trim $10
passenger side front fender (has slight bend) $10
passenger side kick panel $10
power steering reservoir minus cap $5
random interior pipes $0.25
rear bar (one scratch, a small ding and a cracked reverse light) $20
rear seat belts $20
rear calipers x 2 $70
roof lining $10
spare wheel cover $10
spare spacesaver wheels x 4 - useful for keeping a shell rolling. 1 is from my skyline, 3 are from falcons (i think?). I used these when i sold my
wheels/tyres up until the car ended up on jack stands. $20 each or $50 the lot
steering column (minus the bottom part of the shaft) $40
tail lights $40 each
under-dash bar thing $10
under steering wheel trim $10
under windscreen cover $10
front wiper motor $20
fuel pump $20
Headlight wiring loom minus front indicator plugs $20
side mirrors $40 each (driver's side has a small crack on the side)
alternator - had battery juice spilt on it from the accident, might still work $10
bonnet seal $0.50
boost sensor $5
boot lid lock and latch $10
boot rubber seal $10
various boot trim clips $5
castor rod arms $20 each
catalytic convertor sensor $10
centre console brackets $1
centre dome light without cover $5
dash dimmer $10
door seal (the hard one, not the soft rubber one) - i think it's the driver's side $10
driver door loom $5
washer bottle loom $5
ignition loom $10
driver side door solonoid $10
flywheel cover $10
front control arms x 2 $40
front windscreen washers $5
hazard/stereo switch $20
ignition/headlight reminder beeper $5
number plate lights $5 (or free with the front bar)
open door sensors $10
outer door handles $20 each
passenger fog light (lens is ok, plastic a little cracked) $10
hicas module $30
stock rear audio amplifier $5
sun visor clips $5
various metal sheild bits $10 the lot
various trims $name your price
wiper amp $5
wiper switch $20
Hover your mouse over the images below - the descriptions are in the filename which will pop up -
post-49595-0-97266400-1348061831_thumb.jpgpost-49595-0-07195400-1348061836_thumb.jpgpost-49595-0-18719900-1348061840_thumb.jpgpost-49595-0-78787000-1348061846_thumb.jpgpost-49595-0-94654000-1348061851_thumb.jpgpost-49595-0-76036200-1348061856_thumb.jpgpost-49595-0-94840300-1348061860_thumb.jpgpost-49595-0-45373100-1348061867_thumb.jpgpost-49595-0-72708000-1348061872_thumb.jpgpost-49595-0-83452600-1348061877_thumb.jpg[post-49595-0-06683200-1348062174_thumb.jpgpost-49595-0-81306900-1348062181_thumb.jpgpost-49595-0-14020400-1348062185_thumb.jpgpost-49595-0-38362200-1348062191_thumb.jpgpost-49595-0-25074200-1348062196_thumb.jpgpost-49595-0-74292100-1348062200_thumb.jpgpost-49595-0-69283900-1348062205_thumb.jpgpost-49595-0-69241500-1348062209_thumb.jpgpost-49595-0-28226100-1348062214_thumb.jpgpost-49595-0-11974900-1348062245_thumb.jpgpost-49595-0-65492000-1348062248_thumb.jpgpost-49595-0-17601200-1348062253_thumb.jpgpost-49595-0-54064800-1348062257_thumb.jpgpost-49595-0-05342900-1348062262_thumb.jpgpost-49595-0-51312400-1348062265_thumb.jpgpost-49595-0-75468200-1348062270_thumb.jpgpost-49595-0-66857600-1348062275_thumb.jpgpost-49595-0-16849000-1348062280_thumb.jpgpost-49595-0-66312300-1348062284_thumb.jpgpost-49595-0-78320700-1348062353_thumb.jpgpost-49595-0-84767400-1348062358_thumb.jpgpost-49595-0-88934400-1348062362_thumb.jpgpost-49595-0-04651400-1348062365_thumb.jpgpost-49595-0-20698200-1348062367_thumb.jpgpost-49595-0-07607100-1348062371_thumb.jpgpost-49595-0-25783000-1348062373_thumb.jpgpost-49595-0-67889900-1348062376_thumb.jpgpost-49595-0-86932100-1348062378_thumb.jpgpost-49595-0-30793900-1348062382_thumb.jpgpost-49595-0-49850700-1348062622_thumb.jpgpost-49595-0-69623400-1348062624_thumb.jpgpost-49595-0-99086400-1348062626_thumb.jpgpost-49595-0-10704600-1348062629_thumb.jpgpost-49595-0-40356000-1348062631_thumb.jpgpost-49595-0-38345200-1348062633_thumb.jpgpost-49595-0-02602600-1348062635_thumb.jpgpost-49595-0-24273900-1348062637_thumb.jpgpost-49595-0-32352600-1348062642_thumb.jpgpost-49595-0-60335200-1348062644_thumb.jpgpost-49595-0-72434200-1348062697_thumb.jpgpost-49595-0-05352900-1348062700_thumb.jpgpost-49595-0-39537800-1348062702_thumb.jpgpost-49595-0-79666900-1348062704_thumb.jpgpost-49595-0-07167800-1348062707_thumb.jpgpost-49595-0-57441500-1348062709_thumb.jpgpost-49595-0-13499800-1348062712_thumb.jpgpost-49595-0-32040300-1348062714_thumb.jpgpost-49595-0-43085200-1348062716_thumb.jpgpost-49595-0-74347700-1348062719_thumb.jpgpost-49595-0-75005600-1348062796_thumb.jpgpost-49595-0-89449300-1348062798_thumb.jpgpost-49595-0-30280100-1348062801_thumb.jpgpost-49595-0-44030700-1348062803_thumb.jpgpost-49595-0-40430900-1348062805_thumb.jpgpost-49595-0-68033500-1348062807_thumb.jpgpost-49595-0-20386400-1348062809_thumb.jpgpost-49595-0-40002400-1348062811_thumb.jpgpost-49595-0-50849600-1348062813_thumb.jpgpost-49595-0-81706300-1348062815_thumb.jpgpost-49595-0-23306300-1348062867_thumb.jpgpost-49595-0-32260800-1348062869_thumb.jpgpost-49595-0-76539800-1348062871_thumb.jpgpost-49595-0-91949300-1348062873_thumb.jpgpost-49595-0-28136400-1348062876_thumb.jpgpost-49595-0-40875400-1348062878_thumb.jpgpost-49595-0-56440300-1348062880_thumb.jpgpost-49595-0-04427300-1348062883_thumb.jpgpost-49595-0-40983800-1348062885_thumb.jpgpost-49595-0-83439300-1348062887_thumb.jpgpost-49595-0-25158700-1348062932_thumb.jpgpost-49595-0-34752500-1348062934_thumb.jpgpost-49595-0-36401100-1348062936_thumb.jpgpost-49595-0-52685800-1348062938_thumb.jpgpost-49595-0-30987700-1348062941_thumb.jpgpost-49595-0-43684400-1348062943_thumb.jpgpost-49595-0-72175800-1348062945_thumb.jpgpost-49595-0-95165400-1348062947_thumb.jpgpost-49595-0-89140200-1348062951_thumb.jpgpost-49595-0-02960100-1348062954_thumb.jpgpost-49595-0-26918500-1348062988_thumb.jpgpost-49595-0-50217900-1348062990_thumb.jpgpost-49595-0-09646500-1348062992_thumb.jpgpost-49595-0-34989200-1348062994_thumb.jpgpost-49595-0-85686900-1348062996_thumb.jpgpost-49595-0-25008100-1348062999_thumb.jpgpost-49595-0-79433400-1348063002_thumb.jpgpost-49595-0-93560800-1348063004_thumb.jpgpost-49595-0-10501700-1348063007_thumb.jpgpost-49595-0-32023400-1348063009_thumb.jpg
  • Replies 40
Also note that I work in St Kilda near the St Kilda junction, so if you want to pick up from there instead, that can be arranged from about 9am to 6pm weekdays. I'll post anything (except for the larger, fragile items like the front guard and rear bar) at the buyer's expense.
Front brake discs are 30mm so they're roadworthy, but the rears are only 17mm - apparently that isn't roadworthy. (it's an 18mm minimum so i've heard).
4 x rotors - gone!
passenger side front guard - gone!
crossover pipe + bov - gone!
boot hinges + torsion bars - gone!
boot lid lock and latch - gone!
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
