So the car's now gone and i'm left with a bunch of stuff to get rid of!
Old post is here - http://www.skylinesa...point-cook-vic/
This is what's left - i've got nothing else apart from what's here! I've also got a box full of nuts and bolts of all sorts so if you're looking for that kind of thing, feel free to ask, or make an offer on the lot!
Mirror triangle cover thing - $10
rear wiper motor $20
drum brakes (in bits and pieces) $10 for both
Rotors x 4 $70
Pod filter $10
Centre dome light (without cover) $5
front reading lights $10
stock crossover pipe including BOV $20
HICAS computer bits $30
ac pipes $10
blower fan $20
bonnet lining $10
boot hinges and torsion bars $30
bonnet lining $10
boot rear trim light cover $10
brake booster $20
brake pedal $10
engine mounts x 2 $20
centre console hand brake leather $10
centre console front trim $10
cluster surround $20
door sill trims x 2 $10
driver's side kick panel $10
dump pipe (stock) $10
AC evaporator $10
front pipe (stock) $10
fuel tank blanket $0.25
fuel tank strap $0.25
hicas steering rack $30
interior wiring (includes wiring that goes into the boot) $30
jack stands x 4 (only used once! :) $30
passenger side a pillar trim $10
passenger rear arm rest trim $10
passenger side front fender (has slight bend) $10
passenger side kick panel $10
power steering reservoir minus cap $5
random interior pipes $0.25
rear bar (one scratch, a small ding and a cracked reverse light) $20
rear seat belts $20
rear calipers x 2 $70
roof lining $10
spare wheel cover $10
spare spacesaver wheels x 4 - useful for keeping a shell rolling. 1 is from my skyline, 3 are from falcons (i think?). I used these when i sold my
wheels/tyres up until the car ended up on jack stands. $20 each or $50 the lot
steering column (minus the bottom part of the shaft) $40
tail lights $40 each
under-dash bar thing $10
under steering wheel trim $10
under windscreen cover $10
front wiper motor $20
fuel pump $20
Headlight wiring loom minus front indicator plugs $20
side mirrors $40 each (driver's side has a small crack on the side)
alternator - had battery juice spilt on it from the accident, might still work $10
bonnet seal $0.50
boost sensor $5
boot lid lock and latch $10
boot rubber seal $10
various boot trim clips $5
castor rod arms $20 each
catalytic convertor sensor $10
centre console brackets $1
centre dome light without cover $5
dash dimmer $10
door seal (the hard one, not the soft rubber one) - i think it's the driver's side $10
driver door loom $5
washer bottle loom $5
ignition loom $10
driver side door solonoid $10
flywheel cover $10
front control arms x 2 $40
front windscreen washers $5
hazard/stereo switch $20
ignition/headlight reminder beeper $5
number plate lights $5 (or free with the front bar)
open door sensors $10
outer door handles $20 each
passenger fog light (lens is ok, plastic a little cracked) $10
hicas module $30
stock rear audio amplifier $5
sun visor clips $5
various metal sheild bits $10 the lot
various trims $name your price
wiper amp $5
wiper switch $20
Hover your mouse over the images below - the descriptions are in the filename which will pop up -
post-49595-0-97266400-1348061831_thumb.jpgpost-49595-0-07195400-1348061836_thumb.jpgpost-49595-0-18719900-1348061840_thumb.jpgpost-49595-0-78787000-1348061846_thumb.jpgpost-49595-0-94654000-1348061851_thumb.jpgpost-49595-0-76036200-1348061856_thumb.jpgpost-49595-0-94840300-1348061860_thumb.jpgpost-49595-0-45373100-1348061867_thumb.jpgpost-49595-0-72708000-1348061872_thumb.jpgpost-49595-0-83452600-1348061877_thumb.jpg[post-49595-0-06683200-1348062174_thumb.jpgpost-49595-0-81306900-1348062181_thumb.jpgpost-49595-0-14020400-1348062185_thumb.jpgpost-49595-0-38362200-1348062191_thumb.jpgpost-49595-0-25074200-1348062196_thumb.jpgpost-49595-0-74292100-1348062200_thumb.jpgpost-49595-0-69283900-1348062205_thumb.jpgpost-49595-0-69241500-1348062209_thumb.jpgpost-49595-0-28226100-1348062214_thumb.jpgpost-49595-0-11974900-1348062245_thumb.jpgpost-49595-0-65492000-1348062248_thumb.jpgpost-49595-0-17601200-1348062253_thumb.jpgpost-49595-0-54064800-1348062257_thumb.jpgpost-49595-0-05342900-1348062262_thumb.jpgpost-49595-0-51312400-1348062265_thumb.jpgpost-49595-0-75468200-1348062270_thumb.jpgpost-49595-0-66857600-1348062275_thumb.jpgpost-49595-0-16849000-1348062280_thumb.jpgpost-49595-0-66312300-1348062284_thumb.jpgpost-49595-0-78320700-1348062353_thumb.jpgpost-49595-0-84767400-1348062358_thumb.jpgpost-49595-0-88934400-1348062362_thumb.jpgpost-49595-0-04651400-1348062365_thumb.jpgpost-49595-0-20698200-1348062367_thumb.jpgpost-49595-0-07607100-1348062371_thumb.jpgpost-49595-0-25783000-1348062373_thumb.jpgpost-49595-0-67889900-1348062376_thumb.jpgpost-49595-0-86932100-1348062378_thumb.jpgpost-49595-0-30793900-1348062382_thumb.jpgpost-49595-0-49850700-1348062622_thumb.jpgpost-49595-0-69623400-1348062624_thumb.jpgpost-49595-0-99086400-1348062626_thumb.jpgpost-49595-0-10704600-1348062629_thumb.jpgpost-49595-0-40356000-1348062631_thumb.jpgpost-49595-0-38345200-1348062633_thumb.jpgpost-49595-0-02602600-1348062635_thumb.jpgpost-49595-0-24273900-1348062637_thumb.jpgpost-49595-0-32352600-1348062642_thumb.jpgpost-49595-0-60335200-1348062644_thumb.jpgpost-49595-0-72434200-1348062697_thumb.jpgpost-49595-0-05352900-1348062700_thumb.jpgpost-49595-0-39537800-1348062702_thumb.jpgpost-49595-0-79666900-1348062704_thumb.jpgpost-49595-0-07167800-1348062707_thumb.jpgpost-49595-0-57441500-1348062709_thumb.jpgpost-49595-0-13499800-1348062712_thumb.jpgpost-49595-0-32040300-1348062714_thumb.jpgpost-49595-0-43085200-1348062716_thumb.jpgpost-49595-0-74347700-1348062719_thumb.jpgpost-49595-0-75005600-1348062796_thumb.jpgpost-49595-0-89449300-1348062798_thumb.jpgpost-49595-0-30280100-1348062801_thumb.jpgpost-49595-0-44030700-1348062803_thumb.jpgpost-49595-0-40430900-1348062805_thumb.jpgpost-49595-0-68033500-1348062807_thumb.jpgpost-49595-0-20386400-1348062809_thumb.jpgpost-49595-0-40002400-1348062811_thumb.jpgpost-49595-0-50849600-1348062813_thumb.jpgpost-49595-0-81706300-1348062815_thumb.jpgpost-49595-0-23306300-1348062867_thumb.jpgpost-49595-0-32260800-1348062869_thumb.jpgpost-49595-0-76539800-1348062871_thumb.jpgpost-49595-0-91949300-1348062873_thumb.jpgpost-49595-0-28136400-1348062876_thumb.jpgpost-49595-0-40875400-1348062878_thumb.jpgpost-49595-0-56440300-1348062880_thumb.jpgpost-49595-0-04427300-1348062883_thumb.jpgpost-49595-0-40983800-1348062885_thumb.jpgpost-49595-0-83439300-1348062887_thumb.jpgpost-49595-0-25158700-1348062932_thumb.jpgpost-49595-0-34752500-1348062934_thumb.jpgpost-49595-0-36401100-1348062936_thumb.jpgpost-49595-0-52685800-1348062938_thumb.jpgpost-49595-0-30987700-1348062941_thumb.jpgpost-49595-0-43684400-1348062943_thumb.jpgpost-49595-0-72175800-1348062945_thumb.jpgpost-49595-0-95165400-1348062947_thumb.jpgpost-49595-0-89140200-1348062951_thumb.jpgpost-49595-0-02960100-1348062954_thumb.jpgpost-49595-0-26918500-1348062988_thumb.jpgpost-49595-0-50217900-1348062990_thumb.jpgpost-49595-0-09646500-1348062992_thumb.jpgpost-49595-0-34989200-1348062994_thumb.jpgpost-49595-0-85686900-1348062996_thumb.jpgpost-49595-0-25008100-1348062999_thumb.jpgpost-49595-0-79433400-1348063002_thumb.jpgpost-49595-0-93560800-1348063004_thumb.jpgpost-49595-0-10501700-1348063007_thumb.jpgpost-49595-0-32023400-1348063009_thumb.jpg
  • Replies 40
Also note that I work in St Kilda near the St Kilda junction, so if you want to pick up from there instead, that can be arranged from about 9am to 6pm weekdays. I'll post anything (except for the larger, fragile items like the front guard and rear bar) at the buyer's expense.
Front brake discs are 30mm so they're roadworthy, but the rears are only 17mm - apparently that isn't roadworthy. (it's an 18mm minimum so i've heard).
4 x rotors - gone!
passenger side front guard - gone!
crossover pipe + bov - gone!
boot hinges + torsion bars - gone!
boot lid lock and latch - gone!
    • Need to see other side of PCB in that area...ie; I don't see any thru-hole mounting, just soldered vias (smd zeners in SOT23 have 3 legs but only 2 are used, as reflected by PCB tracks)
    • 4 to 5 is fine. It will be slow, but that's better than blowing turbos. I don't have a PS pump idle up solenoid on my car, because... I think when we put the Neo in we retained my R32 lines. But.... From inspecton of the R34 vacuum hose diagram, you can see that the solenoid needs to be connected to the turbo inlet as source of clean air) and the plenum (as source of vacuum - which is the place for the air to flow to to cause the idle to increase). So 3 to 1 is VERY WRONG. 3 should go to either the turbo inlet, or the plenum. Follow the other hose from the PS solenoid and if it goes to the plenum, then your 3 goes to 2 2 would also serve as a bleed port for a boost solenoid.
    • Pull them out and pull more apart. You can't do shit with them still bolted to the floor of the car.
    • Yes it is. ZD1 is on the other side of the board. Where ZD1 is marked is clearly opposite a 2 pin device. Our 3 pin device here is not a ZD.
    • Alright, a little update on this... I called Fulcrum, who used to be the distributor in Australia. No Bueno, they don't service them anymore.  Called shock works, who don't service them but offered to dyno the shocks for performance, and suggested DNA in Sydney might service them.  Called DNA, who also do not service them and basically said they try to steer customers away from tein for this exact reason these days- there is just no support for them anymore apparently.  Both SW and DNA said they are a not necessarily a bad product, but they just don't service the brand or know anyone who does service the brand anymore.  So... I could keep calling around but at this point I think I'll probably just spring for the shockworks product, unless anyone here knows anything.  Cheers 🍻
