Interest so far
Once we have numbers i'll sort out payments etc
1. 4bidn1 X2
2. stag love
3. infiltrator
4. xntrq
5. waino
6. 3Katz
7. shotpointblank
8. rayisboostin ?
Ray postage should only be approx $10 as the packaging is quite small, Count you in ye or ne?
i'll leave this open for a few more days and then i'll send out deposit details, Turnaround from deposits received should be approx 7 days
Cheers guys
Interest so far
1. 4bidn1 X2
2. stag love
3. infiltrator
4. xntrq
5. waino
6. 3Katz
7. shotpointblank
8. rayisboostin ?
Cheers guys
sorry guys im out. because i wanted so many i got the good price over the counter. thanks though :)
I'm in SA
Postage should be around $8 aus wide.
Price may come down a bit but not by much, 8 is what's needed to get this going but i would like to have a few extra to account for last minute backouts
Ok i'll be sending payment info to interested parties
Payment will need to be made within 3 days
once monies have been received it will take roughly 3-5 days for stock to arrive
and i'll have these posted ASAP
Cheers Guys,
Pete
Payments received so far
1. 3katz
2. juzzy.melb
Still only 2 payments so far if you have shown interest please check your PM's for payment details
This has taken a bit of effort to sort out so please give me an indication if your still interested in the GB
Cheers,
Pete
Edited by Fgjoh
1. 4bidn1 X2
2. stag love
3.
4.
5.
6. 3Katz
7. shotpointblank
8. juzzy.melb
9. 533ryc
1. 3katz
2. juzzy.melb
3. 533ryc
waiting for payment to clear
4. 4bidn1 X2
5. Shotpointblank
6. stag love
Still only a few payments so far if you have shown interest please check your PM's for payment details
I'll be refunding monies received if minimum numbers can't be met I'll re check payments tomorrow guys
If this doesnt go ahead i'll be requesting refund details within the next day or so
Cheers,
Pete
Edited by Fgjoh
Sorry guys but 2 more just backed out so this is now no longer going ahead. Anyone who has made payment please PM me with your bank details
Thanks to those who actually followed through but without at least 7 i can't get the discounted price
cheers,
Pete
Welcome to the world of Group Buys. :/
It's a shame when people get super excited about a great idea, but then don't have the stones to admit that they can't really afford it.
Would it be worth posting in the GB section, as you might still be able to get the numbers; just not all Stagea owners.
Good on you for having a go. :thumbsup:
Good idea Dale. Unfortunately I see another yet another SAU members car has been stolen recently, I'll certainly be getting one myself. I like the idea of potentially being able to find my car and perhaps the person/s responsible - to report to police of course. I'll hold off for a while incase Pete decides to have another shot in the GB section although one could hardly blame him if it were too much trouble.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
