Lol
Got the stickers off took me half a day as each letter needed peeling off using my fingernails.
Installed a blitz return flow to get rid of the dodgy piping including 1meter of PVC !!!!!!!!!!!
Just got today a set of project mu pads for the front and a whiteline front bar for later on.
Working sunday so wont make texi, but i will at some stage, it looks sweet.
Lol
you will have to talk slow for nik when speaking of turbo related items, he no understand
Lol
Good work mate! PVC :woot: i hope you used that blue plumbers assembly stuff? :laugh:
Oh poor nick lol.
Wheel shopping will happen in the new year, rego and thailand next month so it will be tight then xmas.
But i have decided on the GTR wheels, dunno if this is hated or been over done but hey.....
I want to do the car right so looking at using good parts hence the MU pads Blitz cooler ETC.
Im still lovin it though these things are so nice and im sure its at stock power levels!
I also need to fix the stock BOV has been blocked off and does not plumb back so big time compresser surge, sounds sweet but i know its bad.
Also bought some dash vents off a member here to replace the last of the painted white bits.
Oh poor nick lol.
zutututututu
if you like the wheels, do it.
its your car, dont let anyone tell you differently.
It's not bad.
But let's not start that debate.
And don't go starting a thread on it.
Copy no ztututututu threads.
I like the noise but you know dont wanna ruin it.
But hey whats a stock turbo worth anyways????
Whats the best way to get rid of the red caliper paint, will i git er dun with thinners or would you replace the calipers
just for ease?
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
