Its a 4" intake off the turbo reduced to 3" to pod filter. Tuner reccomends a better flowing rear housing and a bigger turbine wheel.
He also mentioned when they unbolted the exhaust it gained 20rwkw.
Then u have an exhaust restriction
If he gained 20rwkw from unbolting the exhaust (which does sound like a restriction for sure), raise the boost to about 18psi and add a few degrees of timing from removing the restriction, still sounds like he'll still be falling abit short of where the GTX3076R should be?
Spot on. But with the restriction gone anything can happen
Very true mate. Will be interesting to see what happens when he gets it re-tuned after removing the restriction.
Keep us updated with how you go GotsWapan :)
With the non-garrett turbine housing possibly being the rest of the problem we might have the answer.
IMHO, if I had my time again I would opt for a low-mount over a high-mount simply due to the EPA emissions risk when the po-po pop the bonnet.
With a low-mount, you can keep it hidden and stealth looking if you play your cards right. With a high-mount, it doesn't matter what you paint black or how much heatshielding you use, there's no hiding the aftermarket turbo.
Try sort out the issues with the low-mount if you can, but if you really want a high-mount..... just buy my car instead. I've already sorted out all the headaches, just jump in and drive hahaha :P
Edited by turbodragon
bigger turbine wheel??? maybe the tuner is the problem too.. be better off with an external gate on the 0.82rear, the internal 0.82 costs more anyway..
Edited by SliverS2
    • Welcome back mate ,I also joined in the early 2000's , since then I have been in and out a few times depending if I had a skyline in the garage.  I have the another one now , so signed up and back with the SAU team.
    • I used "different strokes for different folks" quite pointedly as honestly, there is no wrong when it comes to choosing what you like.  I always day dreamed about flappy paddles with fast shifts in a sporty RWD Turbo and to me the sound and feel of it cutting through gears in a steady stream is exciting, engaging, and keeps the car better balanced - I *also* like h-patterns, but I find them more engaging and fun in a nice hoonable peaky NA thing.  Type-R Integra/old school NA rotary, things that are raw and need all the rpm where picking the gear and getting it sky high is part of the engagement of the whole thing despite the fact that they probably need closer ratios and faster shifts even more than a 3l turbo thing haha
    • If I wasn't allowed or really had the desire to visit China it would probably fit in my carry on, but I have no desire, Japan would be nice during Cherry Blossom time though I might need to chat to Jackie about that, that should actually be an easy conversation though as she is currently talking about another cruise, cruise ship to Japan, a week in Japan to see the sights, then cruise home I may even be able to find those OEM NC Recaro seats over there that I cannot find here 🤔
    • What do you mean?  In between the two I shared?  They're the same boost   This will be insane.   A mate has a GTSt with a 9:1 RB30/25 with Tomei 256 cams and a Borg S362SX-E that is already a beast from the basement but has a stock 5 speed and will probably get a ZF8 one day.  After the G35 900 RB26 setup I'd be lying if the topic of "Wtf would a divided G35 be like on this thing?" idea hadn't come up - you'd definitely want a wide boost control range setup with it, as even with the less responsive and potent S361 we're having to ramp boost in from very low levels in the early gears.
    • ZF8 is faster, wider ratio spread, better in every way. I do not dispute this. But I have brain damage and I want the feeling of shifting gears. To me the extra work is fun, but I daily an automatic and in the US like 90+% of cars are automatic so a manual transmission is an "exotic" experience. If I want an automatic I've driven an F80 M3 with DCT more than a few times and it's incredibly capable but it's emotionally vacant to me.
