goin down to a test n tune at willow bank saturday night an was thinkin of getting a set of 275/40r17 Kuhmo KU36's. But a friend pointed out that when they're cold, i'll probably get worse traction then normal street tyres. would this be right? any advice thoughts would be greatly appreciated thanks.
KU36s are normal street tyres. They are just a higher performance one.
Too many people get confused these days and think they are a semi comp, which they simply are not.
So you think they should be fine for traction when they're cold? wishing i had an on/off button for the 4wd so i could warm the rears at the drags...
You have 4WD, you don't need a switch - you need to read the GTR launch threads in this section.
On a decent road tyre you should be able to get ~1.9 60ft in a R33 with 300-380rwkw with some practice. Which is pretty decent.
1.9?? im hopeing to run in the 1.5's, have got 1, 1.59 60ft an some low 1.6's with a set of falken 452's was hoping to run more consistent with a lil more aggressive tyre, i now have bout 340kw atw previous times were when i had about 280kw atw
1.5 will be very impressive if you can manage it.
On an airport surface with Hoosier Drag Radials i was managing 1.5 60ft (8000rpm launches), but then they were on 28psi or so and not under 20psi like they should've.
I forget what i ran with street tyres now. It might actually have been 1.7 - honestly can't remember. Either way a 1.59 is VERY good for street rubber but is indicative of lower power. You might find the rears will turn a bit harder with the extra 60rwkw :)
yer there is a lot of difference between a proper dragstrip an a runway/normal bitumen. 1.5 i would think very good for a run way. well i guess i'll have to flip a coin wether to go for the ku36's of a set of falken 453's n see wot i can do, do you know how much much its safe to drop pressures never experimented with it, but i would think it would help.
I've run 20psi before, didn't give much different in a GTR though from memory. So you can drop them a bit and experiement
Made a difference when i was racing my GTS-R regularly though (between .1-.2 consistently)
How about trying some federal 595 RSR's? same dealio as ku36 but i have found them to be substantially cheaper.
Also ive pulled off consecutive 1.6 60ft with achilles street tyres. 1.67 is my fastest if i recall correctly
:blush: went with the ku36's went to willowbank test an tune last saturday nite. could see it was goin to rain shortly an i would be lucky to get 2 runs so had a stupid idea i'll drive through the water an drop a 4wd burnout to warm the tyres 8000rpm clutch drop with wet tyres, that part seemed to go well but then when i dropped the clutch again to launch a few seconds later the clutch didnt like it, an continued to slip down the strip a lil. never had a prob with it slippin before then when i lined up again thought the clutch mite cool off in that time drove round the water did a clutch drop by the time i got half way down the strip clutch was slippin like a bitch. then would slip goin down the high way on the way home once i got to round 5500rpm, then on sunday didnt slip at all , by sunday nite was handling clutch drops on normal bitumen no problem, so now not sure whether to give the clutch another go at the drags or not...
i went few weeks ago to drags with my new ku36 265/r18 tyres
first few runs with 40psi in the tyres got 1.7x 60ft times, dropped them down to 28psi and was in the 1.6x 60ft times
only 340rwkw
good clutch will be needed to take the abuse :)
Edited by SiR_RB
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
