I've done three of them and they've always bolted straight up, oil and water lines all match up fine. Try find one with the compressor elbow that has the vacuum nipple coming off it factory, I'm fairly sure they come off the R34 turbos
what do you mean no power gain?
RB25 turbo at the same boost the RB20 turbo was set to will produce a fair bit more power.
remember to use the actuator from the RB20 turbo on the RB25 turbo
that way you get 10psi stock instead of the 7psi the RB25 actuator holds.
many years ago, I put a series 1 R33 turbo on an RB20.
with 10.5psi and no tune it made 152rwkw
Also, R33 and R34 turbos are not the same.
R34 turbo has a bigger rear and will be laggier on teh RB20.
Stick to R33 turbo.
just go to an exhaust place, tell them to remove the intercooler piping that goes from the turbo tot he cooler, and tap a nipple to the pipe as close to the turbo as they can.
that is where the vacuum line from the actuator will go.
The one i drive was laggy with the 33 turbo on the RB20 anyway, pretty stock sort of setup.... Not sure if its an RB20 thing or due to the bigger turbo?
If its an original a31 rb20det, the water lines have a different (smaller) banjo bolt. can't remember size, m16 (a31) instead of m18( r32, r33) maybe.
Got caught out when I did this on my first cefiro.
So you can get water lines off a r32 rb20, they will work, or make up custom water feed/return lines.
And yeah, you'll see some gains. worthwhile mod if you need to replace turbo anyway.
Edited by CEF33Y
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
