Anyone on here playing this?
More importantly anyone playing with a wheel on PS3? My Logitech Driving Force GT makes the car nearly undriveable, feels like it has loads of understeer, So far its ruining the game for me a bit.
I'm sure its not just my lack of skill
https://www.sau.com.au/forums/topic/410313-formula-1-2012-f1-2012/
  • 3 weeks later...
read the codemasters forum,
i think there is an update to fix this.
gameplay is definitely different from 2011, and had to get use to it all over again, i was understeering heaps at the beginning but now have got use to the gameplay and im driving normal now.
using the DFGT but on PC.
awesome graphics and gameplay, i love it!
I worked out my issue with the steering wheel.
In 2011 you could just yank the wheel full to the left/right and it would just steer as hard as it could
in 2012 if you do this it will understeer, you have to use more of a shallow turn of the wheel the faster you go. My mistake to start off with, and now that I'm used to it I really like it, makes it a bit more real
At the start I was struggling on Professional but now I think I might have to go back to Legend. There's a few things that aren't on the game that should be, like being able to watch the practice/qualifying sessions
But all in all its am improvement over F1 2011
Just chiming in here that I've been really into F1 2012 lately. Like most of you I struggled with the understeer compared with F1 2011 initially but a few tweaks to the setup on my G25 and I've gotten the hang of it now.
Have been throwing the car around a bit lately in Korea, India and now Abu Dhabi :D
Started playing again last week after not touching it for months... Career mode, driving for force india in my first season... On Pro I can't get anywhere near the AI, but one skill level down (intermediate I think?) and I'm smashing them consistently by 2-3 seconds a lap. The gap between the 2 skill levels is too big imo...
I'm using a controller though, so I don't think it's possible to drive very well with it when you can't really regulate braking/acceleration/turning... Anyone else gone from controller to wheel and noticed a massive difference in their times?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
