im selling my R33 remapped ecu with supporting mods made 210kw @12psi
mods are as follows:3 inch exhaust ,stock turbo,stock injectors,fmic,stock afm.
can send pics of dyno sheet if needed.great cheap upgrade to ur r33
$250
i can tell you.. toshis tunes are one of the best.. i will always get my stock ecu remaped throuogh him, so much beta then aftermarket ecu!, and safer..
exactly why the topic says "with supporting mods"
Did u read past the words "with supporting mods"? If u didn't, it clearly states stock turbo.
So back to my question.....
Edited by White_33
standard turbo can handle a max of 14psi but safely will handle 12psi.u can run 10psi with this ecu but u will probly only make 200kw.
sorry guys i stuffed up with the price toshi sells these for $650 plus cost me a tank of fuel so i want $350 for it.still very safe and cheap power upgrade for any r33 with suporting mods
I do not sell $650.
I charged to him $550 real time road tune for his car include chip and ecu modified.
Straight from the man himself. Offer in my pm is still there if you're still interested.
  • 2 years later...
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
