Have been playing the following albums over the past few days
Mobb Deep - The Infamous (1995)
Biggie - Ready To Die (1994)
NAS - Illmatic (1994)
Public Enemy - Fear Of A Black Planet (1990)
WuTang - Enter The Wu-Tang (1993)
Luniz - Operation Stackola (1995)
JayZ - Reasonable Doubt (1996)
A Tribe Called Quest - Low End Theory (1991)
Awesome albums.
Hahaha.
Also been listening to;
Jeru The Damaja - The Sun Rises In The East (1994)
Raekwon - Only Built 4 Cuban Linx (1995)
A Tribe Called Quest - Midnight Marauders (1994)
Kool G Rap & DJ Polo - Live and Let Die (1992)
Ice Cube - The Predator (1993)
OutKast - Aquemini (1998)
Bone Thugs - E 1999 Eternal (1994)
Artifacts - Between A Rock and a Hard Place (1994)
Nas/Lauryn Hill - It Was Written (1006)
Lots more too, but I didn't think many people would be that into it. :)
Naice list!
llmatic is the shit, nuff said.
Fear of a Black Planet is a ridiculously influential album - awesome stuff!
Enter the Wu Tang - the original posse record, "Here I go, deep type flow Jacques Cousteau could never get this low!"
Raekwon back when they called him the Chef on the motherfarken CD cover!
Tribe, Ice Cube, Bone Thugs.... just an awesome list :D
Edited by Hank Scorpio
  • Replies 3.5k
You guys would love the rest of the stuff that's playing at the moment if you like those ones!
I'm sure I would, it's usually the sort of thing that I have cranking.
My latest acquisition (as of this morning) was Rahzel's "Make the Music 2000".
Awesome. Old Rahzel, the human beatbox.
Also;
Eric B & Rakim - Don't sweat the technique (1002)
Public Enemy - Muse Sick-N-Hour Mess Age (1994)
The Roots - Illadephia Half Life (1996)
Naughty By Nature - 19 Naughty III (1993)
OutKast - ATLiens (1996)
DJ Quik - Born And Raised In Compton (1991)
Gang Starr - Hard To Earn (1994)
Bone Thugs - Creepin' OPn Ah Come Up (1994)
2pac - Strictly 4 My N.I.G.G.A.Z (1994)
Brand Nubian - One For All (1991)
Geto Boys - We Can't Be Stopped (1991)
Mos Def - Black On Both Sides (1999)
O.C - Word...Life (1994)
Queen Latifah - Black Reign (1994)
Digable Planets - Reachin' (1993)
Method Man - Tical (1994)
Cypress Hill - Black Sunday (1993)
Nas - It Was Written (1996) (Side note, not as good as Illmatic)
UGK - Too Hard To Swallow (1992)
Ice Cube - Amerikkka's Most Wanted (1990)
Goodie Mob - Soul Food (1995)
Junior M.A.F.I.A - Conspiracy (1995)
Snoop Dogg - Doggy Style (1994)
Warren G - G Funk Era (1994)
Da Brat - Funkdafied (1994)
LL Cool J - Mama Said Knock You Out (1991)
Mobb Deep - Hell On Earth (1996)
Dr Dre - The Chronic (1993)
Naughty By Nature - Poverty's Paradise (1995)
Busta Rhymes - When Disaster Strikes (1997)
Big Punisher - Capital Punishment (1998)
DMX - It's Dark and Hell Is Hot (1998)
Busta Rhymes - The Coming (1996)
Pharoahe Monch - Internal Affairs (1999)
YoungBloodz ft Big Boi - Against Da Grain (1999)
Few more, but you get the idea. Hahaha.
Did you see him when he toured Australia ~2011?
Was an awesome gig, came with DJ JS-1 and they were fkn AMAZING!
Also - you can't listen to LL's "Momma Said Knock You Out" without listening to Kool Moe Dee's "How Ya Like Me Now" ;)
Nah, I wanted to go, but missed out because my mate was meant to get the tickets, then ended up hitting the greenery instead, and forgot. Bastard. I still haven't forgave him to this day.
Will check out How Ya Like Me Now, tonight. I don't think I've got that one. ;)
You definitely missed out, was one of the best I've ever been to.
On the cover of How Ya Like Me Now check out the red kangol hat underneath the LHF wheel, very sly ;)
Awesome albums.
Just checked out most of these albums, you are a true connoisseur of 90s rap/hip hop.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
