Just wanting to know what everyone thinks re order of works, brands and models etc. Like a menu reference for someone like me and others with a Stagea and new to modifying.
I.e
Fmic best suited.
Safe boost for stock turbo.
What larger turbo to use.
Etc etc etc.
But broken down into
1.
2.
3.
With what other owners have done.
Regards.
Justin
It would help to know how much money you want to spend over what period of time and if you have a power goal but some very basics:
1. 3in turbo back exhaust.
2. High flow panel filter for your airbox (supposing you still have the stock airbox).
3. Bypass the boost solenoid and get a cheap boost T (or an expensive electronic boost controller if your'e so inclined) and run about 10psi.
4. Heavy duty sway bar (anti-roll bar) for the rear e.g. Whiteline BNR11 XX 24mm) which will dramatically improve cornering.
5. Plan to get a brand new fuel pump.
Check to see if your auto fluid has been replaced (ever) and think about getting a S2 or aftermarket trans cooler. Replace your brake fluid with something like Motul RBF600. Check your rotors and if ok get some quality pads next time.
Have a look around this forum for lots more ideas of how to lighten your wallet and make your car better! Read the RB25DET turbo upgrade in the forced induction section for examples of mods and what they have acheived.
Basic mods people do:
Turbo back exhaust- better flowing especially in top end.
FMIC- depending on plans for car.
Boost controller- increase boost, standard turbo 10psi, 12 Max.
Air filter- panel better in standard box as said above.
Sway bars- front and rear if possible for best handling.
Strut braces- ordered through importer from Japan.
Coolers- oil, trans, depending on Wat car will be used for.
Turbos- high flow of standard, high flow + 3076 internal conversion an frot housing changed, 3076r. All with braided lines.
Brakes- better pads, and new rotors, or upgrade to r33 or r34 brakes with slotted rotors and good pads, or brembo with more modifications.
Head work- cams, cam gears, oil restrictors (I believe are needed in the neo's.
Suspension-full adjustable arms
Coilovers/lowered springs- depends on wat the owner prefers interms of stiffness and adjustability and use of car as too Wat is best for the car.
This is basic list. Depending on price and how far u want to go. And Wat the car is used for. On phone so can't put wat is best when. But as most people would hopefully think he same, always try to upgrade ur handling and brakes (ie safety stuff) before starting in power. I find ways the point in the power if the car can't stop or handle a corner.
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
