Hey all,
This started happening yesterday morning, but was hard to diagnose due to lots of condensation (was a bit chilly yesterday morning). Basically what happened, is when i would drive off, then stop, smoke would come out. And when i accelerate then back off. Smoke would come out again. Doesn't look like it comes out while actually accelerating, only in between. (if that makes sense?)
After work, i got the old man to follow me around, he said only a small puff came out when i left my house then nothing but a bit of blackish/grey smoke under boost (normal i believe with a stock ECU). Did a few tests, light load - high/low revs, 4th under load up hill and WOT. small cloud of smoke under boost. Werid...
Anyway, while i was driving today i noticed quite a alarming rate of smoke coming from my exhaust, i pulled in and took this video.
https://dl.dropbox.c...1009_082732.mp4
It won't smoke when it is idling, but when accelerating it puffs out like crazy, the car was warm when the video was taking. It seems worse when the engine is cold. Looks like a bluey smoke, so im thinking oil??
Tips on how to diagnose whats wrong with my car appreciated!
Temps seem fine, Still goes the same (not that i gave it a hard time due to the smoke screen).
Hoping its turbo related because i am replacing them. I'm scared to drive on it, and you know have this lame thing called work, really don't want my engine to go BOOM
Edited by Booki
https://www.sau.com.au/forums/topic/411139-gtr-blowing-smoke-help-troubleshoot/
  • Replies 43
Looks like condensation. Chilly morning = condensation, especially if you don't drive the car very much.
Take the car for a long drive and see if it still does it when the weather is warm (read - above 20deg c)
I thought it was condensation too, But I dunno. It seemed a little "blue" and heavy for condensation.
I will take another vid when I move to my next job site.
Hado - I checked my coolant last night, looked normal green color. Will check it before i drive off again.
Ok, Started it up to go drop it at home.
No smoke...Revved it a little, no smoke. Wasn't even worth taking a video.
Even on the drive home, nothing came out.
Decided to play it safe, and drop the car off at home. Gave it a bit of a rev when i got in the garage and a small puff came out, but then nothing after wards.
Beats me... It was BAD this morning. Now, nothing. Regardless using the bike till i figure out wtf is going on.
and Hado - Coolant levels normal, still green.
Update: checked coolant. Its used some, although it is still clean of what i can see of it. Checked oil cap, and all looks good from that view, as well dipstick oil. Color looks normal. So i don't think its a head gasket (least im hoping not)
Stock turbos
Edited by Booki
white smoke on rb26 usually means turbo seals. have a look in the coolant reservoir tank. can you smell oil? incorrect anti-freeze ratio can also cause white puffs of smoke. do full coolant flush from block and see how it goes from there. my gtr does it on WOT. no biggie.
Starting to replace my turbo's, and noticed the rear one was seeping oil.
Intercooler also had some oil in it too.
So far have all the piping off, turbo heat sheilds off, undone the front pipe bolts to the dumps.
It's coming along alright so far, only because the old man is helping out (by helping out i mean doing 90% of it).
Hopefully we don't get stuck, the job itself doesn't seem hard. Its just all the variables (rusted nuts/bolts, tight space) that make it difficult.
Dam RB26
  • 3 weeks later...
Ok....Started up the GTR with BRAND NEW -7 turbo's, let it idle for a bit while i was putting in my fresh coolant (you know the drill) and the same shitty smoke was there.
No where near as bad as the video posted up, but still noticeable.
Idea's?
Hard to tell, Only started it twice.
Turbo's have only just been put on, have not driven car due to it not being tuned.
The smoke is hard to describe, it looks like condensation but right now its about 22 degrees? So i don't think its condensation.
Smoke comes out on de-acceleration.
Only revved it as high as 2500-3000rpm
I have a similar issue with a customers car. I tried a new pcv Valve to eliminate it from the diagnosis and the issue is still there.
As Dan has said, more than likely valve stem seals.
They are a pain to diagnose tho.
Have u done comp and leakdown test?
Havnt done compression or leak down tests yet. Will do some more trouble shooting when I finish up work for the day. Hoping its not a head gasket or rebuild time, only put 5000kms on it since ownership :(
Will try and get a video up, keep me posted on how you go with your customers car :)
Edited by Booki
    • I have wasted too much time on this, more than I am willing to admit. I hope someone can set the record straight for me.  I want to replace my Nismo (non GT pro, non GT) standard 2 way in my R33 GTST with a 1.5 way... Ideally I want to get an ATS 1.5 way Carbon LSD, but I don't want to reuse my 29 spline 5x1 axle stubs, and new 30 spline 5x1's are impossible to get a hold of ($$$), and I don't want to drop the cash on going to 6x1 stubs and axles ATM. Which leads me to the Nismo GT Pro 38420-RSS15-B5 or RSS20, as they come with new axle stubs meant for the diff, and is "Convertible" from a 2 way or 1.5 way to "Other ways", but that is where I am stuck as the documentation is a bit all over the place.  To sum up what I have found I believe the all the Nismo GT Pro PN's are convertible from 2 way, 1.5 way, and 1 way; but Nismo sells 2 skus (2 & 1.5) so people do not have to disassemble to convert it.  I found this thread on 350z but it left the question unanswered. https://my350z.com/forum/engine-and-drivetrain/620032-nismo-gt-pro-lsd-1-5-vs-2-way-and-torque.html  Essentially the way I think it all works out is like follows...  2 way  1 way  and 1.5 way would be the center pinion shaft in the 1 way block, but with the with the center flipped 180*. So the ramped side of the pinion would face the 1 way gate and act like a ramp.    I can only get my hands on the 2 way in the states, and I am not trying to get stuffed on tariffs by ordering from Japan or anywhere else. I want to confirm that if I get the 2 way I can convert it to the 1.5.
    • Hi everyone, I have purchased my first GTR and I want to do a single turbo conversion to it. I've been doing as much research as i can and there are a few things that I can find and need to know. I need to run a coolant feed, coolant return, oil feed and oil return for my turbo setup. Here's what I know so far: On the hot side of the rb26 there is coolant feed, oil feed and oil return. Coolant return will be going around the front of the engine to where the thermostat is located. I will need to block off the rear oil return port. I will be running a turbosmart boost solenoid so any of the factory boost stuff wont be needed. Now onto what I don't know: 1. What do I do with the coolant / vacuum hardlines that run around the back of the motor?. 2. What do I block off or loop or move or remove?. I will be running the OEM intake manifold. 3. Is there anything in particular I need to buy for the cold side of the rb26?. I already have the intercooler and pipes sorted. If you have any pictures or information it would be appreciated. Thanks....
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
