  • Replies 43
hey mate interested in motor/gearbox package please pm me number
cheers
PM sent !
Hi mate, I am interested in the engine if its still available. Thanks
PM sent
How much for the frontbar and the garnish between head lights posted to 2620 queanbeyan
Sorry mate the front bar and grille are both sold
I want that PFC but i don't have the cash at the moment! sell it to me and I'll pay you off weekly XD
Haha, if you're serious I would take a non-refundable deposit on the PFC and i'll hold it (for a while) for you till you get the full amount
i am but I'm better off to save my pennies :( and just buy one when i have the dosh..
No worries
Hi mate just checking if gearbox still available if so call or sms me on 0412392232 thanks Tom
SMS sent !
hey im very interested in the FMIC , to fit it do you have to cut a hole in the body of the car tho?
text me 0407604714
Sorry mate I sold the FMIC last weekend
  • 3 weeks later...
Hey mate, just wondering if you've still got the ignition barrel/key barrels and the RHS door trim and or window switch. Cheers.
