Hey guys..
Been told that some coolant can chew away ya alloy head from a rb25det...
I currently 'techalloy' 100...the green stuff...been told its good but can damage my head...
Wat do other ppl use that would be better then that and lasts longer..??
Thanks guys
https://www.sau.com.au/forums/topic/411426-coolant/
Hey guys..
Thanks guys
No it wont eat the head unless its left beyond date or km to change
Do not mix with any other brands or levels of protection that causes "eating away "
Do not use tap water ever !! unless your stranded then dump asap the aussie tap water is harsh on alloy etc, distilled water
Do not water down the mix it should be about 50 /50 or premixed
if you add redline water wetter or motul cool it helps the heat transfer
If you add any stop leak get it flushed out asap after you get home
ground ( engine) upgrades can help the process keeping corrosion away strange as it sounds and helps with spark, charging etc
never run water only unless its just to get it home
its a high performance engine so use a decent brand and grade of coolant
Service regular
The tech-alloy is fine
Green or red
Prestone from usa is great stuff as well
Motul
Nissan
And a few random brands just never mix them!!
https://www.sau.com.au/forums/topic/411426-coolant/#findComment-6577126
as above. the biggest thing to watch out for are idiot mechanics that top up red coolant with green. gums up the radiator, you gotta replace it.. don't ask how I know!
if changing between red and green make sure you flush it out thoroughly.
besides that, red or green.. whatever floats your boat.
https://www.sau.com.au/forums/topic/411426-coolant/#findComment-6579759
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
