Honestly, if you are sick of the sound I know where your coming from, thats why I changed mine
And it doesnt really matter what you choose as long as its a plumback, there are to many issues with the Atmo BOV's (Search and you will find) so make sure you get a plumback
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579403
Yea Cal, pretty over it, its a bit boring i guess lol
I have heard about a few good read ups on the Gtr ones so might give one a go.
And remember dude the coast is still pretty hostile with the boys in blue so keep it legal :thumbsup:
Maybe see you on Sunday?
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579462
are the stock ones good enought for gt30's? must be alot of air to move for the blow off valve.
when i back off the throttle im getting a quietish zututututu...
Edited by SliverS2
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579473
Mine failed a long time ago, it was sticking open and not getting boost etc..... Not commen from what ive seen but made a big difference when i put the new plumback on and got some zutututu action too :P
Yep ur not wrong Mat, thats why im trying to keep things looking stockish i guess ha
Yea man possibly, i will let u no during the week for sure, cheers
Yeah good plan, keep out of trouble!
Let me know if you can come say G'day and meet some of the members even if you cant make the run :)
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579484
AFAIK the stock BOV works fine on most Gt30 series turbos, plenty of people running GT3076's etc with stock/GTR bov's
Mine is a Greddy Type RS Rip off, but im Considering getting a genuine. So if that happens I will probably sell mine which has a custom plumback adapter on it (as the genuine one doesnt fit and the rip off doesn't come with one)
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579490
Haha im hoping so. Yeah man for sure im pretty keen, hopefully install my coilovers this week, would be sweet to give em a run
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579535
I think its the pressure that is a concern for them sealing, and they do flutter to a degree so its obviously a lot of air but alse depends on the position, factory position is pretty good as its close to the TB, the GFB one i have now still flutters a bit even on soft setting, but its a LONG way from the TB.....
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579536
Mine went on on the weekend, have a look -
http://www.skylinesaustralia.com/forums/topic/358438-34geeteetee-daily-track-project/page__st__400
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579537
Thansk mate, if you dont make this cruise dont worry as we plan on doing stuff at least monthly! November will be an exception as a couple of us are entered in the SAU Nats :D
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579547
Sweeeeet, sounds good man!
If you join as a member there is a members section with a Newy/Coast chat thread where questions like these will be answered by the guys for ya :D
Plus for the price of membership you get a heap of value, stickers, lanyard, shirt and discounts off purchases at some places AND it give you better pricing for events etc :yes:
https://www.sau.com.au/forums/topic/411581-bov-options-r33/#findComment-6579557
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
