  • 4 weeks later...
so slowly making more progress!
Got the head back and i think i twas worth the wait. little bit peeved I didn't get a flow chart or a cc measurement of the combustion chambers which i thought would be pretty standard but o well at least its done and ready to bolt on!
IT will be fun when its done but the problem is in WA no one believes in customer service or getting a job done in a timely fashion..
unfortunately no it wont be ready for race wars to much work on at the moment but funnily enough i will have all of April to get it finished so im a month to late. Shame would have been some good competition, i wanted to see if i could max the new speedo i got for it.
The head work is care of Godzilla motorsports cnc programits not cheap but its a dam sight bettter and cheaper then some hand porting jobs!
I have all my parts pretty much now so i just have to wait to get some time off work to put it all together!
stay tuned though its gonna be wild!
  • 5 months later...
hey guys havent updated this in a while thought i would put some current pictures up!
this is how she's looking at moment waiting to go to intune to get the pipe work and bits and pieces i haven't finished. Hopefully ill make it to power cruise!
  • 4 months later...
  • 1 month later...
No real update yet it's at the shop still it's almost finished! Ended up changing fuel system to run e85. See how this flex fuel thing goes!
Didn't realise how big the r type hks intercooler was till it was fitted, not a lot of clearance there!
I'll get some more pictures up shortly!
Yeh funny you should say that I had hoped to get it to racewars last year.. And here we are.
Well you will laugh at the gearbox selection.. I'm going to run the standard one at the moment. Can't make my mind up yet I was convinced a ppg rebuild would be the go but I decided if it was going to be dog box it has to be sequential but I would I was loosing sight of what the car is actually going to be used for! And that is to drive it to work everyday and the odd track day..
Simon is pushing 700whp through a standard box, however look at how he races and treats the box very gentle on the shifts and very smooth but still pretty quick shift.
he just hoards stock 32 R boxes at home.
i am chasing similar power and have opted for a 34 Getrag in my 32, slightly stronger, similar to yourself i want to keep it semi streetable so i didnt want a dog box.
Forget about a dog box for daily driving. Sequential would be a waste unless it was strictly a weekend + track car only. For 5-600rwhp the OS Giken kit or a helical PPG would be a better option. Although, the standard boxes can cop a fair amount of power.
Yeh I thought I would wait and see how long it lasts and exactly what breaks. I had thought the best option would be an os set with the billet plate and agy synchros so I'm trying to get onto the synchros at the moment and then build up the parts list from there. I've got a spare one anyways so there won't be much down time anyhow.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
