I dont know what PPG is like nowadays but if they are anything like they used to be stick with the OS gear set. Although only a 2 wheel drive we have been using the full gear set for years now and its perfect
How many pumps are in that surge tank? and what pump are you running?
Yeh I think I'll be running os gear set agy synchros and galvs billet sandwich plate when I build the box I have decided but I want to see how long this one last first! Pretty pricey build I just hope I don't kick myself for not going for the more proven tougher set ups first up too soon!
  • 4 months later...
So it's been a long time since I posted on here but the car is finally running! Big day on the dyno tomorrow!attachicon.gifImageUploadedBySAU Community1404984430.634811.jpg
Very nice mate, good luck with the tune! Looking forward to seeing how it performs :)
Car wasn't ready to pick up in the end so hopefully run in will be done this weekend!
Considering I drove it Friday and still have a broken leg I think I'll wait the last few weeks till it's better to get the full tune! Would hate for the thing to get away from me!
  • 4 weeks later...
  • 5 weeks later...
Finally got some power down today!! Still not finished need to fit some stiffer gate springs yet which will make it even more exciting!! But she made some nice power without braking a sweat which says a lot for this little turbo!
  • 3 weeks later...
Bit of an update got another tune after sorting the gate springs and gate control now.
Made 626hp @30psi but loads and loads of torque. The response is ridiculous I will have to get a pic of the dyno graph this week but I think that is the absolute max the little gtx35 wants to push out the rear of it so for now that will be all unfortunately until something bigger is strapped on!
Another update though...
A RE401B with manual valve body has found its way into the car over the weekend to help with some up coming drag racing duties.
I'm sure this will get lots of hate! No doubt it will go back to manual one day but you can't beat a built auto for drags!
Having said that hopefully it makes powercruise so I can put it to the test!
  • Like 2
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
    • Wrong side of sydney for me coming from Goulburn, but you should head along, all ages of Skylines will be very welcome
