Jamie's picture made it to the 7Tune page:
http://www.facebook....&type=1
Not sure who Shaun Wilton is
but credit to the photo should have atleast gone to Jamie or atleast SAU VIC as it was posted last night on our FB page
Have sent 7Tune a message!
Which GTR is yours again?
Oh yeah! 7 Tune!
Shaun Wilton owns the Blue R34 GTR with the White TE37's (HIRISK).
Thanks bro! :D
Sorry if I upset anyone or did not follow protocol.
I am not up to speed with the done thing in these online situations - showing my age.
Sorry - I can ask 7 Tune to pull the photos if you like?
  • Replies 254
I am not up to speed with the done thing in these situations.
Don't sweat, wouldn't worry about it! :D
It's all good. Atleast credit is going to a SAU VIC member lol :)
All good man!
Good you did post it up on 7 Tune!
Get more coverage :D
Just waiting on confirmation on some cars.
But 5-6 cars have been picked from one of supporters who will be providing the $1,200 detail package prize.
I'll be putting up the pics on FB and letting the public decide the winner with the most likes over a week :thumbsup:
I get puns like that all the time due to my forum name. Haha
There is some serious prizes...
Will have to check the fb page out...
Hey guys,
Thanks for a good day. First SAU outing and it was good. Sort of long time reader first time participant lol.
Also signed up as a member, so win win :)
After Sunday I will be going to more things in the short time frame I have.
Also, you guys have some really nice Skylines, was spoiled for choice in what to look at
Alvin how are ya mate, still haven't come back to the dark side yet... haha how's the new ride treating ya?
Lol.. nah.. supras are getting cheaper now. but i'm still disappointed with toyota after the whole soarer thing..
maybe when i get richer.
auto daily 34 is great though.. =x
Do the winners of the SnS all win the $1200 detailing package or every class somthing different?
Cars in their respective classes will receive trophy. Not sure when we find this out, but should be soon. Hurry up John or Dan!
Only one car will receive the detailing package. These cars were picked by our supporter at Immaculate Reflections. The guys who will be giving out the prize. Then we will let the public decide on the winner. Announcement on the cars picked should be sometime tonight, then we will let it run for a week. Most FB likes wins!
Are we concerned that the owner with the best networking skills / Facebook friends will nail that prize?
Anyone want to be friends on Facebook?! ;)
I'll vote for your car :P
Trophies were done by a panel of judges
Detail prize is a mixture of cars picked by some judges and then by public
Just trying to mix it up so the public can also get involved.
Last year trophies were voted by the public and prizes were given away in a raffle. So just something a bit different this year
Sounds good and I guess it will increase exposure to the club via social media, which can't be a bad thing.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
