Hey guys,
Ive decided to sell my well looked after R32 GTS-T, is in great condition.
YouTube Clip of car -
Carsales Ad -http://www.carsales.com.au/private/details/nissan-skyline-1992-13529578?postcode=3173&base=1216&vertical=Car&cr=0&eapi=2&__N=1246+1247+1252+1282+903+1216&find=1992%20Skyline|CarAll&distance=25&silo=Stock&num=15&Range=Year:1992,1992|Price:Min,10000~1&sort=default
Has 144XXX kms on clock!!
Serviced at every 5000kms.
Manual Transmission.
RB20DET.
Only ever filled up with BP ULTIMATE.
Gunmetal Grey paint, with Legit black GTR Bonnet and GTR grill.
GTR front bar (aftermarket)
GTR V-Spec II Boot (legit), with lip and wing.
Front mount intercooler.
Op6 R34 GTT Turbo.
Full 3" Turbo back exhaust with Hi-flow Cat.
Nistune.
550cc Injectors.
Yellowjacket Coilpacks.
Platinum Spark Plugs.
Z32 AFM (legit Bosch part) (still have stock one if need).
K&N Panel Filter.
GFB Boost Controller.
Apexi Turbo Timer.
18" Wheels with Roadworthy Tyres.
Very dark tinted windows.
Bilstein Shocks.
King springs.
White HID Dash Cluster Lights.
Aircon & heater works perfectly.
Was tuned by Trent and Cat at Chequerred Tuning.
Everything works as from factory, including fold in mirrors, electric windows, all interior lights etc
Doors are sound deadened for better sound quality.
Car Dynod in at 176rwkw, drives absolutely perfect, was slowly building it to one day drift it, but as u can see its too nice to drift and that would kill it.
Has been my daily driver for the past few years, but recently sold my business and have commenced studying again and need a car I can leave at the train station without worrying that my beloved r32 will get stolen, scratched or broken into etc.
Had an oil leak from the front main seal, just recently (on the 19 Sep 2012) got it fixed - set me back $1000, for new seals and water pump and cambelt!
If u know me, u know how well i take care of my cars, one drive and u will see.
THE BAD POINTS
Car needs paint on the roof as it is a bit oxidized. The car is from 1992, so paint isn't going be absolutely perfect.
There is a small dint near the fuel cap, where the previous owner had given his car to his mechanic and the mechanic reversed the car into a pole, Probably cos the tint is so dark haha!
For car to be roadworthy u will need to remove tint.
Asking $8000 FIRM with NO RWC.
Reg Expires 21 Nov 2012.
Please, no tire kickers. Car is genuinely a regretful sale, my loss is your gain.
NO SWAPS!!
Thanks.
Marcus.
Mobile - 0415 038 232.
Email - [email protected]
Edited by Widesays
Deposit has been given, awaiting full payment on Wednesday. So car at this point is sold, if anything change will post up here :)
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
