I've owned this car since it was purchased brand new and its a regretful sale. With a new house being build plus a 2nd child on the way, 1 luxury item had to go.
Regularly serviced with full logbook history. Oil changed every 5000kms. Brand new Brembo front brake rotor & pads as well as a full set of tyres fitted less then 1000kms ago. Car has never seen the 1/4mile or tracked.
Year
- 2009 5sp Manual GSR
Power mods
- Forced Performance Evo Red Turbo (ported & upgraded 25psi actuator)
- Forced Performance Turbo High Flow Oil Supply line
- Forced Performance Turbo Inline Oil Filter
- Forced Performance Turbo Gaskets set
- HKS Aluminum Turbo Intake Pipe
- Cosworth Highflow Airfilter
- Grimspeed 3Port Boost Solenoid
- Works upgraded BOV
- ARP Head Studs
- BC 272/272 Camshaft
- BC Valve Springs
- BC Titanium Valve spring retainers
- AMS Fuel Rail Kit
- DW 1000cc Injectors
- MAP/AEM Fuel Pressure Regulator Kit (with gauge)
- BLAQOPS Fuel Pump Upgrade Kit with E85 Safe Lines
- Walbro 255 Fuel Pump
- Depo Racing 3inch Upper & Lower Intercooler piping Kit
- Custom 3.5inch Bar & Plate Intercooler
- Ultimate Racing 3inch Turbo Back Twin Exhaust (inc dump pipe, 100cel highflow cat)
Handling mods
- Swift Spec-R lowered sports springs
- Cosco Strut Brace
- Rota Grids 18 x 9.5 +20 (with 265/35/18 rubber)
Interior mods
- HKS Type-1 Turbo timer
- LC-1 Wideband & Gauge
Exterior mods
- Mitsubishi USDM Door Window Visors
- Mitsubishi USDM Side Number Plate Mount.
- ARC Carbon Air Duct
Engine mods fitted by
- Tyron at Fortitude Valley Ultra tune (former NA Autosport Mechanic)
Tune
- Dual Map tune(98Oct & E85)
Power @ Wheels
- 98Oct: 280kw
- E85: 315kw
Price $47000. All reasonable offer will consider.
Pics:
https://www.sau.com.au/forums/topic/412147-evo-x-gsr-315kwwheels/
For anyone new to Evos, these are very impressive numbers for the car. I've seen this on carsales for a while, have been keen to see some interiors and engine bays though - Might help your sale :)
The interior is stock like any other X. Like my GTR, under the bonnet I've make it look as stock as possible to make it less attractive to the popo... But if you think it will help with the sale, I'll try and take some pics tonight and post it up. :yes:
Edited by Blitz_R33
  • 3 weeks later...
  • 1 month later...
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
