it's well known cars in US (even Japan) are always a good .3 -.5 sec quicker down the strip compared to what you can achieve on aussie soil - like for like
i think the main reason is the way they measure roll out, which on a hard launched awd car is a noticeable time advantage
Martin's 10.3 for eg would be close to a 10 flat on a US drag strip
a more accurate comparison when looking at acceleration times from different countries is the 60-130mph
Edited by domino_z
Its easy to make big power out of these stock engines. The trick is to keep the stock rods inside the engine over the vehicles life......
Getting a one-off drag number isnt so hard if you put your mind to it. It certainly impresses a lot that dont understand the risks, and the massive potential cost, involved
Why you would spend 10's of thousands of dollars on modifications for an extra 0.1 to 0.3 of a second over a 1/4 mile is beyond me. Especially with these kind of results with just a mid pipe and tune. A good video this one, some nice shots taken from inside and outside the car.
#! Edited by GT-R OZ
That's exactly right. People who spend that kind of money to get such a miniscule increase in performance (which they would hardly ever use anyway) don't do it because it actually makes any sense, they simply do it because they can! :yes:
Edited by GT-R OZ
Sorry off-topic.
Hey Domino, how did you install your rear diffuser fins? Did you have to drill the carbon panel under the car?
I like the look and should reduce soot on the back of the car. Did you find any difference?
Thanks.
i get absolutely zero soot daily driving on e85, that's the best solution to reducing carbon emissions..... or Martin should have the new injector end pulse tables for cobb which may help on 98 Ron
im not sure what part you're referring too
I am running the top racing carbon lower diffuser which replaces the oem part
These are the hks kansai diffuser fins I bought a while ago. I haven't installed them yet, looks like you have to drill into the oem carbon diffuser. I had to paint the leading edge on both pieces matte black as they were quite rough looking with excess resin
but i can't see how either part could possibly reduce soot
Edited by domino_z
Hey Dom -
Yup, that's the one - the Kansai diffuser fins. I thought you had installed that (saw your NAGTROC post).
Apart from the the good looks, the diffuser fins should extend the turbulent wake further behind the car at high speed, therefore reducing accumulation of exhaust output onto the rear face of the car. It should therefore reduce drag and improve rear downforce in conjunction with the rear upper spoiler.
^ Whoop-dee-do!
What would that cost the average consumer... just to put things into perspective.
Around $5K all up is what most GTR retailers will sell this kind of package for depending on existing mods already in place (ie. exhaust etc). and what brand parts they use. Not bad for a daily driven 10 second car :)
Many different kits from many different parts upgrade manufacturers to do this on these great cars. GTRs are a great base, which is why we all like them so much here.
    • As I wait for parts to be delivered, I have managed to procure via a contact a R32 Nistune ECU......for now I just want to monitor what the car is doing but eventually.......who knows where we go 😂
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
