Hey Guys,
Got a 32GTR with a steering vibration. Seems to have had this issue from day i got it but i could barely notice it.
Up around the 90-120 mark i get a bad vibration through the steering wheel. . It almost seems the get worse the longer i drive, but i can't tell 100%, its semi intermittent.
Have an aftermarket Momo which came with the car. Also have HICAS Deleted with lock bar and all removed. It appears i have a R33 Power steer pump. It has a line going to the rack (Pressure) and a line coming from the reseviour connected to it, no other hicas etc.
I have had:
Wheels changed, Wheels balanced. Had a full wheel alignment done. Power steering fluid full, no leaks.
Checked coilovers for loose bolts, suspension arms, adjustable camber arms. Wheel bearings are ok both sides, were done less than 2 yrs ago. I pulled the power steering pump off and inspected it. All the vanes look fine, and bearings/seals are good. All bushes are new in the front end, and steering rack ends don't have any play.
I had the drivers side CV Rebuilt (had a click).
All wheelnuts are the same, all there (New) and wheels studs OK. It almost feels like the wheels are going to fall off, but i've pulled over and checked many times.
Where do i go next? Steering rack? any further tests i can try? If so, do i get it rebuilt, or can i buy a new one?
Thanks
Aaron
https://www.sau.com.au/forums/topic/412773-steering-vibration-highway-speeds/
see if there is any free play with your front steering rack and also the hicas lock bar's tie rods, then proceed in checking all the ball joints.. chances are there is some form of free play in them.
Changing the wheels has no effect. Have a completely different set on, and tried swapping F to R on the old ones.
Had a look at the rack play, definitly isn't shagged.
Might need to double check the tie rod bushs in the rear, havn't looked at them.
I did have my front right CV rebuilt, is it possible the left is gone too and causing a vibration? I only did the front right because it was clicking under lock.
Racks ends? Caster bushes?
FYI:
I was surprised the difference from doing all the wheel bolts up to the same torque. When I get new tyres, and the stupid places always rattle run them up, I get home and crack off the nuts and do them back up in the right order with a torque meter, to 100Nm. It's noticeable, but not the the extent you seem to be talking about.
no buckles on the opposite side of the wheels that you cant see? .i had steering vibration in my ssv ute , couldnt work out why until one day i happened to notice the slightest flat spots , mind you they were 20s but as soon as i got new wheels problem sorted .
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
