Psychopharmacology, Nuttitional Psych, Hypnotherapy, Counselling
I sort of love the detective work of tracking genetics, ancestry, biochemistry and microbiology most of all.
For instance us Asians tend to lack Lactase (thus lactose intolerant), Aldehyde Dehydrogenase (we get drunk quicker), don't process Vit A as well as Caucasians and we're often born with big teeth on small mandibles (common to have wisdom teeth extractions)...
https://www.sau.com.au/forums/topic/412794-sleeping/page/7/#findComment-6901222
So you carry your bottle of Lacteze to dinner?
Funny how I sometimes recommend it but I don't have any myself.
Birds I don't have dairy very often away from home, and I'm usually too full to order a cheese platter.
Yoghurts can get me going sometimes.
I think Lactaze or Tilactase has short dating for those considering it.
https://www.sau.com.au/forums/topic/412794-sleeping/page/7/#findComment-6901254
interesting
I'd love to find something to help me with my sleeping issues, but I don't want to take any medication so I probably can't
I don't like taking prescribed drugs myself unless absolutely necessary - but supplements are a different matter (when justified).
https://www.sau.com.au/forums/topic/412794-sleeping/page/7/#findComment-6901257
I may have mentioned before - maybe not - that different supplements may be more useful than others depending on the type...
Insomnia Type I - where one can't get off to sleep...
Insomnia Type II - where one wakes up intermittently
Insomnia Type III - where one wakes up too early and can't go off again
Rider:- Rotating shift work, pregnancy, cardiac issues (like fibrillations and mitral valve weakness) can upset all of the above
https://www.sau.com.au/forums/topic/412794-sleeping/page/7/#findComment-6901529
I have insomnia type 2 most nights and type 1 about once or twice a week, when something upsetting has happened during the day or I'm anxious. I usually get between 3-5 hours a sleep per night for about the past 7 years. I'm pretty used to working full time, studying part time and going to the gym 6 days a week on little sleep now; however I think lack of sleep affects me emotionally.
https://www.sau.com.au/forums/topic/412794-sleeping/page/7/#findComment-6901728
A long time ago, I had insomnia of a similar kind for over 5 yrs Leesh. I used medication to 'reset' the sleep pattern so to speak over a few months. I went days without sleep sometimes. Eventually it caused me some physical health issues.
Also, you fall into a pattern and the 'lack of sleep' thoughts further add to your stress ,causing more lack of sleep.
The medication I used basically 'puched my lights out' at a time when I wanted to go to sleep. It had some side effects that I would say are nothing compared to long term lack of sleep and go away the moment you stop taking them.
Go ask your doctor to help you out there it's worth it.
https://www.sau.com.au/forums/topic/412794-sleeping/page/7/#findComment-6901886
If you want a otc supplement try Dorian Yates GH Blast. It has GABA, ZMA, arginine glutamine and macuna purians in it very good testosterone and GH support and assists sleep
I have a hormone imbalance and my body produces excess testosterone, so is this supplement appropriate for me?
https://www.sau.com.au/forums/topic/412794-sleeping/page/7/#findComment-6902435
From what I understand all the claimed test booster do not boost testosterone they support the natural balance between test and estrogen. There is not artificial boosting at all. That ingredient macuna puriens helps with the balance. And if your test is high, lucky you because most of the 'normal range' levels sited by western medicine are too low. It has been proven that test from ancient non-westernized humans are close to double the level of westernized men. They also have non existent rates of heart disease, diabetes, obesity and hormonal issues we have. So I would not worry really because men with so called normal range test are less likely to create waves and a lot easier to control.... exactly what the government want.
Edited by XGTRX
https://www.sau.com.au/forums/topic/412794-sleeping/page/7/#findComment-6902460
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
