From what I understand all the claimed test booster do not boost testosterone they support the natural balance between test and estrogen. There is not artificial boosting at all. That ingredient macuna puriens helps with the balance. And if your test is high, lucky you because most of the 'normal range' levels sited by western medicine are too low. It has been proven that test from ancient non-westernized humans are close to double the level of westernized men. They also have non existent rates of heart disease, diabetes, obesity and hormonal issues we have. So I would not worry really because men with so called normal range test are less likely to create waves and a lot easier to control.... exactly what the government want.
fair enough, but I'm a female.
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6902501
Ooops forget about the latter rant then. Out of interest what is the ratio between test and estrogen.
I'd have to tell you that when I'm at home.
So I'm still slightly confused as to what is an appropriate supplement for me to take
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6902652
Leesh.
Phenibut pure.
That Dorian Yates stuff is expensive repackaging, no points for guessing Mr Yates didn't get his huge size thanks to this stuff.
Don't think Dorian is a goal body shape for you ?
This is why I think the Yates powder is having a lend:
* It's not going to boost test (if it did it would be illegal).
* ZMA , called zinc tablets (when not being touted by muscle building supliment companies), is basically $6 for a bottle of 100 tablets from Cenovis, with the Zinc Magnesium & B vitamin ratios that work. IF you are deficient.
* Maca Puriens contains trace amounts of L-DOPA as it's claim to fame (so do ordinary broad beans), thats not a hormone balancer of any kind.
* GABA has a weak amount scientific evidence for it's effects, given it can't pass the blood brain barrier. So it's mechanism for efficacy is not known if it can work.
Phenibut can pass this barrier hence is evidenced as being effective and understanding of the mechanisim.
There is Phenibut in this stuff but, it's an undisclosed amount. That is the part that works.
Phenibut is about 3c to 12c a serve and works vs $2 - $4 a serve for the effective part.
Edited by rev210
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6903287
All the points above are valid however if you want to try an all in one sleep aid then I recommend this. Why? Because it actually does assist sleep. As with a lot of blends and also foods in general, the sum of the parts create different results than looking at the individual contents in isolation. For people not bothered to search for individual ingredients this is good to purchase. If you get results then search for the ingredients individually. And yes the claims are stupid as with any other body building supplement. $50 isn't a bad investment if it works, and it will work as it has for the 20 plus people I have recommended it to over the last 2 years.
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6903603
I understand. You are quite right that it would assist sleep (contains Phenibut). I think you have a good point as Phenibut isn't an easy suppliment to find.
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6903611
#@rev210
I'm looking at purchasing Phenibut from the Primaforce website; do you suggest the powder? There are tablets on there too but I don't think they're pure Phenibut, plus they have gelatin in them.
Just want to confirm the powder is what I should be getting before I purchase, thank you.
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6911130
#@rev210
I got it from ebay. from this place.
http://www.ebay.com.au/itm/Phenibut-100g-Pure-Nootropic-Go-out-have-fun-dont-drink-Wicked-Gear-/290935953856?pt=LH_DefaultDomain_15&hash=item43bd2259c0
Taste is like very strong grapefruit juice (acidic) in water. It's only $36 for 100g. Bargain.
Edited by rev210
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6911836
I tried ronnie colemans resurrect pm but I think I have issues with the tryptophan in it as it gives me anxiety attacks ( I already take tryptophan during the day ) I have tried gh blast which has GABA included and that seems to help me alot better. Let me know how that powder works l33sh as at about $90 a tub of gh blast it sends me broke rather quick
Edited by Kenna802
https://www.sau.com.au/forums/topic/412794-sleeping/page/8/#findComment-6926070
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
