I actually had sleep last night!! Have not had a good nights sleep for almost 2 weeks. I am not sure if it was all the choc protein shakes but it has been terrible. Even GH bLast didn't work. Finally got some last night with the aid of valerian forte and melatonin 6x . ( Strange yet when I tried the gaba and phenibut the other day it did nothing ) I have stopped choc protein and gone to a different flav
My sleep has gone to shit the past week or so. I can get to sleep ok, but then wake up anywhere from about midnight to 3am, then it takes up to 2 hours to get back to sleep. I think it was because my normal sleep pattern was disrupted by the tour de France.......
I tried phenibut and melatonin last night; got to sleep quicker and only woke up once, but when I woke I was dripping in sweat. Had a few upsetting dreams last night not sure if related to phenibut/melatonin or not.
Melatonin would likely be responsible for the dreams. Why did you want to use both at once?
Took phenibut again last night; definitely sleeping better, got 6 hours which is the most I've slept in a few months. However when I wake up I'm dripping in sweat. This morning was worse than Sunday night, my hair is wet and clothes are dripping wet. I'm a bit concerned. I know other people here have taken phenibut, is this normal?
I've woken up nights in a row dripping in sweat when I've been having perfectly fine sleep and not supplementing anything (just to suggest it might not be related). I've actually almost concluded the reason I'm sweating is from lying in the one position for too long - but no idea why my body wasn't rolling over while I slept...meh
this used to happen to me during last year, no matter what the season (actually, not in summer) so the reason would not be overheating for me. I use the same blankets/doonas for all seasons so it's not like in winter i stack on extra layers either. very strange. also, sometimes it's just my legs/lower half of body that sweats, rarely is it my upper body too. also no supps except for protein i believe
Yeah I definitely wasn't overheating, that's for sure.
Easy test Leesh - stick with the phenibut for a week or so and see if sweating persists. If so, stop taking it for a week and see if sweating goes away. If sweating goes away, start taking it again just to confirm it's the cause (as in theory, sweating should return).
If it appears to be the cause, speak to yer docta ;)
Could it be due to an elevated immune response. Seeing that you are sleeping longer and more restfully could it be that your body has a better opportunity to heal and you immune system is working in overdrive. Just a thought.
possibly? I really have no idea.
Where's the best place you guys would recommend getting melatonin? After the last couple of weeks, particularly last night, I'm about ready to start slamming xanax - if only so I can fast forward through my f**king atrocious nights.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
