haha all good Rev, was only joking :P Cheers though.
Seems the scoop it comes with should be roughly 300mg. Might crack out the milligram scales though, don't wanna f**k around with this stuff too much haha
Knew you would have a milligram scales...
amazing how for years i couldnt sleep. and i mean years of living on 3-4 hours a night.
now i just go to sleep. pop a little tv on in bed and im out with in an hour. also have a new bed which makes it even easier to drift off.
good stuff. sleep well guys!
My mattress was $1800. Everyone who has slept on it says it's amazing.
I get around 3 hours a sleep a night.
Last night: Went to bed at 12.30pm, went to sleep round 2.00am, woke up at 5.00am went back to sleep, woke up to my alarm at 6.15am. That's actually good for me.
haha yeah it's kinda the same here - my mattress would've been a super el'cheapo, but everyone who's slept on it reckons it's comfy as! I hate it though :unsure:
It's so unbelievably tempting to go out and blow a couple grand on a mattress...but I'm worried it won't make any difference :( bah!
Go buy one; you spend nearly 1/3 of your life on one, yet you'll spend 10k on a car that you spend an hour a day in...
My mattress cost $2500 and after considering the above, it's nothing in the scheme of things. Particularly when you get 15 years out of them versus a car. Whether or not it makes a difference to sleep quality, you should have a good mattress for your body.
I don't disagree for a second there bruz.....but that's $2500 I could spend on a trip to Canada for snooooooooowwwwww :P
I'll go have a looky this weekend i think, no excuses since Makin' Matresses is just around the corner from my gym (which is only 5 mins from home LOL)
Went out for a while last night to hang with my mate while he worked, as well as to purposely make myself extra sleepy...
well it worked haha, slept like a log...only just not for very long thanks to bed at 2am and alarm at 7. Oh well feel pretty good today.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
