okay i don't know for 100% but this is definitely not looking good.
how much did you pay for the car and can you get your money back ???
maybe if you got it "for a steal" you can just sorta ... sell to scrap metal... and wash your hands of the whole situation,... cos SEVS has no Q45 i can see
and being a 1989 - it cant qualify for pre 89 rule either...
...im sorry, man!
  • Replies 145
Posted Images
eps being a 2004 import and an 1989 model it would have been imported under the old 15 year old scheme which did not require 15 year old cars to be complied just had to be modified where necessary to meet basic ADRs and then be signed off by an engineer for rego. the exact requirements vary from state to state.
you might have some problems explaining why the car was not complied in 6 years since it was imported. luckily for you the scheme still exists but in a more restricted format (no longer rolling 15year window, now fixed at 1988 and older) so you may be able to find people who still do this type of work and know what needs to be done to your vehicle.
I'm assuming you still have the VIA? you'll need that at the least. As to whether or not you can replace the engine before getting it signed off and registered I would be asking that question of the registering authority in your state and the engineer or workshop who is going to be getting it done for you. you may still have a problem with it not being complied for 6 years but as far as I know there is no expiry date on the VIA once the car is imported so you may be ok.
richard - my mistake! I thought that as it wasn't ''complied'' before the 15 year rule was phased out, then he'd have no luck... If thats the case then he'd want paperwork at least showing when the car was imported!! But thanks for correcting me
yes, VIA = Vehicle Import Approval. No car can be imported to aus without one and that piece of paper will state under what scheme the vehicle was imported. that info will tell you whether or not it could be complied. as to whether or not it still can be you would need to check with DOTARS. personally I would do it sooner rather than later. the longer you leave it the higher the chance that some rule will change preventing you from getting it registered. even if you don't want to register it right now still get the work required to meet ADRs done and get the engineers sign off. That way you wont have problems when the time comes. but if it was under the 15yo scheme you should be fine. but again, my advice doesn't matter, only DOTARS can tell you what the deal is.
    • Before starting any work, we attempted to adjust the tune. However even after adjusting it to certain extremes like completely stopping fuel, it had no effect. What fixed it was removing the Nistune Board and installing the original EPROM instead. This immediately fixed the issue. Everything should have been fine with the Nistune Board installation, so I am unsure why it has caused a problem. The soldered connector is also properly soldered. This worked when I first got the 550cc injectors, before cleaning, but that may have been a coincidence.  We ended up not installing the fuel pump hanger (at least for now). So currently running stock injectors, stock fuel pump, stock fuel pump hanger – Well everything stock except the exhaust. Now I have around €1400 in Nistune, Injectors, and Hanger collecting dust for the time being, perhaps I'll install them in the future. For now I'll enjoy the car as is 😁 Thanks a lot for all your assistance, I really appreciate all the help you have given me.
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
    • Ok, just the way you wrote it made it look like you had the stagger the wrong way around
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
