6 nuts to be undone from inside the boot ... 3 either side below the lights towards the outside of the car.. 12mm if i remember right... then you have to remove the "skyline" from between the lights (4 nuts from behind plastic panel near latch) then there will be 2-3 clips on a shelf the bar sits on......... then slide it out!!
oh and check out the number plate mount.. will have to remove plate and possibly the mount too... i removed mine but not sure if essential!!
hope this helps
hope this helps
cool... i'll use this when my bodykit finally arrives.
you mention the "skyline" between the lights. do you know where I can get a hold of the "skyline" that actually illuminates? i don't know if this is an extra thing or if it's part of the series 1 skylines?
be very interested in getting a hold of one of those...
i have the SKYLINE PART off this gtr i am wrecking. what you wanna pay for it? its silver
really? nice... so it is the "skyline" section that is of the see-through type indicator plastic material type thingo-ma-boby-ma-jig (beware; i'm getting highly technical here)...? i'm not interested unless it lights up, because i've seen a few of them and they do look very cool and very rice'y..
cost? no idea... what's the going rate?
myr332, the ones that light up are from series 1 gtst's cause they are clear, just have to install led's behind it.. i put a neon back there but it's not big enough.. will be hooking up led's soon!
you also have to paint the panel around the letters if you only want the letters lighting up, or leave it if you want all of it (skyline has silver chrome paint on it standard)..
i think they go for about $250 F-Off-Buckaroos at a wreckers.  thats just too much for rice in my oppinion...hehe.  its only 20bucks or so here per sack at the local groceries:D:D
LOL, but does it GLOW??? :headbang:
so all I have to do is go to a wreckers and buy the see-through variety skyline plate? do they have these packaged anywhere (including the required neon) that I can buy off the shelf, or will it be a bit of a DIY job?
thanks for your help! :)
no hes not. heslooking for a Series 1 R33 GTSt centre skline panel. stop acting like MR KNOW IT ALL.
Learn to read you rude little twat
offcourse i read what he said, i was offering him something and you don thave to interupt like on all of my other sales.
You are a moron that clearly has an issue comprehending plain english.
I was clarifying what myr332 appeared to be looking for to assist your thread and attempt to prevent confusion.
Enough crying
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
