  LaL said:
no hes not. heslooking for a Series 1 R33 GTSt centre skline panel. stop acting like MR KNOW IT ALL.
  myr332 said:
do you know where I can get a hold of the "skyline" that actually illuminates?
Hey f00lz0r... he IS looking for one that illuminates...
Did hitting that bus stop affect your brain and the way it performs daily functions? Like spinning crap on SAU?
Guest RedLineGTR
1. Remove Boot Trim (the Sides at least)
2. Remove Skyline Centre Panel
3. Remove Plastic Clips/Screws Under skyline Panel ( which has been removed)
4. Remove Bolt From Licence Plate That hold the bracket (cant remeber if it holds the bar as well)
5. Plastic Screws/Bolts at the bottom of the car that hold onto brackets.
6. Remove the 3 bolts on each side of the rear bar (from the inside where you have removed the interior boot carpet) just have a feel around with your hand you should be able to get to them with a socket set.
That should be the all the screws that need to be removed, but just do a visual check of the rear bar before you pull it off (do it gently to make sure).
Hope it helps, Cheers Rob
PM me If anything.
