hey guys, both rims came off an r33
stock r33 rims (no tyres) perfect condition not a scratch on any rim, like new = $250 (sold as a set)
stock r33 with brand new falken tyres 225/55/16 = $600
stock r33 rims with tyres (just over road worthy) = $300
Pursuit (steelies) rims with Yokohama Guardex 600 studless 205/55/16 (tyres feel really really soft) = make an offer as i have no idea of its market value
pm or email [email protected] for more info if required
thanks :headspin:
https://www.sau.com.au/forums/topic/41369-track-rimstyres-stock-r33-rims-250/
I have to agree with the above comment. Those are snow tyres and worth very little money. If you are willing to part with the tyres for a cheap price i would be happy to purchase them. Could do with some "fun" tyres.
PM me with a price for tyres only.
whoa! why does soo many ppl want 2 stocko rims? Would really like to keep the stock rims 2gether as 1 set only. Would like $250 and these ones are practically new - not a mark on them!
  • 3 months later...
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
