Hey guys I am located on the Gold Coast, willing to post items at cost or pick up and currently have the following for sale;
R32 GTR (Will fit GTST) Aftermarket vented fibreglass bonnet, It is ADR approved and comes with approval documents, It has been fitted with bonnet pins but has the catch part and will work with r32 gtr standard bonnet catch system. The holes can easily be covered with a plate or filled in, or ready to run bonnet pins, can supply bonnet pins if req. It is professionally painted in jet black, no scratches painted underside aswell.
Bonnet$1000, Bonnet Pins $10, Bonnet hinges $40
R32 GTR Projector style Headlights L/H and R/H, also R32 GTR Indicators (All will fit GTST as well) All in perfect condition lenses mounts everything and comes with bulbs and rear covers etc.
Headlights $200pair Indicators $100pair (RH indicator has tiny crack, barely noticeable)
R32 Side Mirrors Black, R/h has slight damage as seen in pic, LH is undamaged $60
R32 GTR Passenger seat Immaculate condition, with rail, all movements working perfectly $300
Also have a std R32 Gtst drivers seat laying around in good condition for $50, and GTR rear seats in perfect condition for $120
Nismo Dash Cluster R32 GTR (320km/h and 10000rpm) (Will fit any R32) Immaculate condition with only just over 40000kms on it. $350
Momo steering wheel in perfect condition, also have an immaculate genuine horn button to fit. Steer wheel $150, Button $30
R32 Gtr Front strut Brace Avg Condition $120
Names Johnny I would rather you call or txt, otherwise please PM, avoid posting on the topic thanks
0414596256
https://www.sau.com.au/forums/topic/413850-r32-gtr-parts/
More parts listed;
R32 GTR genuine Front Grill Very good condition $150
R32 GTR genuine front bar very good cond $300
R32 GTR genuine front lip $150
R32 gear and handbrake boots white with nismo imprint $50
R32 gtst A/C digital control unit $60
R32 GTR/Gtst centre console plastic surround $50
HKS intake kit for GTR with 3A racing pods only used for 2000km $200
Alloy 54mm radiator to suit R32 GTR/Gtst with silicone hoses only used for 2000km also have radiator brackets $200
Autometer Tacho with shift light $20 perfect working cond, with all brackets wiring req.
Plenty more bits and pieces from $20, adjustable arms etc stripping whole car including built rb26 with hks 2530's, PM or txt/call for further deets or other parts
Edited by slidinr32gtr
https://www.sau.com.au/forums/topic/413850-r32-gtr-parts/#findComment-6633596
Gear and hand brake boots sold, as well as just the speedometer dial in the cluster, rest of cluster still for sale for $40, More Parts FOR SALE
Pwr FC hand controller $300
Power fc d-jetro map sensors and loom $300
Intercooler 600x300x100 $200 3" inlet/outlet big hks style tube and fin
3" cooler piping from twin turbo pipe to plenum $200 incl hose clamps and silicone joiners
Trust Type R BOV $300 stiff spring type
R32 REO $50
R32 Overflow bottle good cond $40
Door cards $60 pair
PM or txt for pics
https://www.sau.com.au/forums/topic/413850-r32-gtr-parts/#findComment-6636473
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
