Hey guys time to get rid of some bits
2x Nismo LMGT4's 18x9.5 + 18 ( Matt black with bit of gutter rash and crap tyres) $1050
2 x Work XT7's 4 Stud 17x9 + 18 powdercoated black with Toyo R1R tyres 95% tread 235/40/17 $1100
2x Std R32 RB26 turbo's (came off a working car I was told) $100 the pair
2x R34 GT-R STD Stainless Steel dump pipes $200 the pair
1x R33 GT-R Intake Plenum freshly stripped and powdercoated satin black $220.00
Set of GT-R Throttle Bodies $100
Pair of brand new RDA 324mm rotors ( with some surface rust but never used) $200 with a free set of endless brake pads used but lots of meat.
Set of dog bone adapters to use r32/33 caliper on 324mm GTR rotor (80% sure these are for a GTS-T $80.00
BeeR rev limiter $80.00 used
R32 GT-R engine loom in good condition $160.00
Twin turbo pipe in std silver wit elbow for rear turbo in good condition $80.00
HKS VPC ( vain pressure controller) so you can run a map sensor on STD or remapped ECU including harness and remapped ecu $200.00
I am sure there is more but this is a good start
Email me collins.andrew.acATgmail.com
or sms 0434425026
Cheers
Located near baswater vic and can post at buyers expense.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
