Hey all,
selling my skyline r32 due to not having time to fix it.
price: inbox me an offer.
everything is great condition just the front needs to be fixed.
motor,gearbox,diff etc... is all running perfect and all the parts.
has GTR brakes.
5spd manual(awesome condition)
clutch is fairly new :)
rb20det with rb25 turbo, motor got 160k on the clock.
side mount cooler,stock air box(good shit to have to clear those gay yellow stickers)
LSD diff.
basically car is stock.
the left indicator cheated death! and is alive and well...
I'd love to keep it, but no time at all to fix it at all :(
just took the reg off it.
so inbox me an offer and i'll get back to you :)
preston...
price people can inbox me what they like to buy it. but im waiting replys
offers have been going from 1,500 to 2,300
  • 2 months later...
ok so i was going to keep it and fix. couldnt let it go.
but now ive come to a time in my life that i have no time for it...
i got a lot of shit to do. and i will have no time to fix it :(
selling price $1,500(doesnt sell in a week, will be selling at $2,000)
i would swap this for a reg ke70 must be (4 or 5spd manual,flat front) and not be full rusted!!!
i want to keep it. but id rather have it go to a good home, then to have it do nothing all the time.
it can be reg'd. i took it off due to rather get money back and not to waste the rego for nothing.
very easy to get a roadie done to it. but must fix front first obviously..
bonnet,reo bar,front bar,headlights, right indicator, radiator. is all you need to fix it :D
Edited by AndreW_R32
  • 1 month later...
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
