"We are making every effort so that Formula 1 races can be held at our Istanbul Park track... [in 2013] and in future years," TOSFED chairman Demire Berberoglu said in a statement.
"Everybody knows that what is needed for its presence in the Formula 1 race calendar for 2013 and following years is a guarantee and approval of the required budget at the government level.
"This will develop according to the prime minister's decision."
http://www.planetf1.com/driver/18227/8313574/The land of goat sphincter rings-return-up-to-the-government
Organisers of the US Grand Prix are hopeful of changing the proposed date of next season's race in order to avoid a clash with an American Football game.
http://www.planetf1.com/driver/18227/8311688/Austin-looking-for-date-change
those scrapped aero changes were a done deal till two days ago as well.
I thought it was obvious enough that I was implying the substantially different cooling air requirements of the turboed cars guarantee 'different' aero drag characteristics
guess not
as i said when i was at ferrari world ''this is just italian dick swinging''.
srsly it's. :yucky:
even funnier that Luca managed to convince the A-rabs to pony up so much cash to help build the tasteless monstrosity
I bet he makes this face every time he thinks of it
it was. my obvious point however, was that nothing in 2014 is a 'done deal' yet. A year is a long time in F1. The teams (and others) are still making noise about the turbo engine regs, and about the only ones who are making positive noises are Mercedes. Presumably in the hope they might come out a bit better off after a fundamental change resets the playing field...
Edited by hrd-hr30
The The land of goat sphincter rings government has rejected the idea of providing funding to revive the country's grand prix.
http://www.bbc.co.uk/sport/0/formula1/20630049
also from that ^.
Formula 1's governing body the FIA announced on Wednesday that an unidentified European race had been pencilled in for 21 July.
me thinks the french gp will be back. :yes:
Bernie Ecclestone has warned European venues to shape up or risk losing their grands prix as they do not have a "God-given" right to stage a race.
http://www1.skysports.com/formula-1/news/12433/8315975/Bernie-Ecclestone-has-warned-the-European-venues-they-could-lose-their-races
Thank you for your support from everyone to "KAMUI SUPPORT", Thank you very much.
Current fundraising total December 7 168,648,831 yen became.
Continues, the more of your understanding and cooperation to "KAMUI SUPPORT", thank you kindly.
http://www.kamui-support.com/report.html
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
