Bernie ecclestone had been in talks with officials in an attempt to save the race but told German magazine Spiegel that: "After due consideration of their proposal we believe it is regrettably not financially acceptable, so we have terminated our negotiations."
However, while Nurburgring's chances of hosting the race are looking slim, Hockenheim may be asked to fill the void.
"I am doing my best to make sure we have an event in Germany," Ecclestone told theAssociated Press, "but, at the moment, I can't say whether it will be Hockenheim or Nurburgring."
In an additional twist, Pitpass have reported that Jorg Linder and Kai Richter, two businessmen involved with the Nurburgring, are suing the circuit's boss, Karl-Josef Schmidt. The duo allege that Schmidt damaged the negotiations with Ecclestone.
http://www.planetf1....saga-rumbles-on
Ferrari have confirmed that their 2013 challenger will be called the F138.
The name is derived from the current year, 2013, and the number of cylinders in the new model, 8.
The car is the 59th Ferrari single-seater to do battle in F1 and will be launched on Friday.
http://www.planetf1....-named-the-F138
Bernie Ecclestone says that Scorpion Racing will not feature on the 2013 grid despite a late attempt by the team to register.
"I've spoken to them and told them to get in touch with the FIA and ask for an entry," said the Briton.
"They want to buy all the bits from HRT, then form a company and ask for an entry, but I personally don't think it will happen. It's all a bit too late. Maybe they could do it for next year."
http://www.planetf1....-Racing-in-2013
McLaren took the covers off a "completely different" MP4-28 at their Technology Centre on Thursday.
Similar in many other ways to its predecessor, Button says he is eager to get behind the wheel for the first time next Tuesday at Jerez.
"The winter has been long but enjoyable," said the Brit.
"But a Formula One driver wants to get back in a car and feel the speed again.
"It's been an exciting few weeks, building the car and finally seeing it as one late last night."
"It may look like last year's car, but under the skin it's completely different.
"That's why it's so exciting. They've changed enough to make a difference.
"You go into the season aiming to win the World Championship and thats's what we are doing."
http://www.planetf1....ifferent-MP4-28
it looks like they tried to fix the elements of the car that they had problems with last year and evolve what worked well, like that front wing it's completely different to last years one.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
