Teammate comparisons in order of the percentage of points contributed by the number two:
4. Hamilton 62 vs 6. Rosberg 47 = 75.8% points and -2 positions
13 Ricciardo 7 vs 15 Vergne 5 = 71.4% points and -2 positions
3. Alonso 78 vs 7. Massa 45 = 57.7% points and -4 positions
8. Di Resta 28 vs 11 Sutil 16 = 57.1% points and -3 positions
1. Vettel 105 vs 5.Webber 57 = 53.3% points and -4positions
10 Button 25 vs 12 Perez 12 = 48% ponts and -2 positions
2. Kimi 86 vs 9. Grosjean 26 = 30.2% points and -7 positions
Massa ranks 3rd overall and best of the big 4 teams other than Rosberg at Mercedes.
All I can say is Lotus must be desperate for the money Grosjean has behind him!
Edited by hrd-hr30
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
