Years later I still dont get all the fuss over Mika. Never rated him...he needed the team to hand him wins and the team principal to completely mess with the head of his team mate ... then with the car under him was able to do the job. He is a Button at best
Because Finn
Everybody who wins the WDC had the car under them
He recognised his opportunity and got the job done, thats what is impressive
Isnt that right webber, fisichella, massa, rubens, coulthard, irvine etc
Coulthard, even with his retirement and rookie errors here and there was the pace setter. What Coulthard showed me was that the mental space of a F1 driver needs to be a pretty strong place. Coulthard wasnt and Old Ron having man love for Mika screwed with Coulthard in a very negative way.
Same can be said for Schumacher, Alonso, Lewis, and now Seb
Mika is alright, he's no top 5 driver or anything, but fcuk me, he's a boat load better than button
That fcuking hack. He makes me sick. If anything Button and Massa are the same person
Not sure thats true. I dont think Webber's performances have suffered due to Seb having a surrogate dad as team principal. The Alonso Massa thing has clearly messed with Massa's head space who alongside Schuey really grew into his own for a few seasons against TGF and Kimi. Alonso and the culture of the place does seem to have damaged Massa who other then the rare weekends like of late has been totally out classed by Alonso.
Lewis, well its less Lewis and the same offending team principal that was around when Montoya and Alonso walked rather than play the game.
Anyway...fark Mika. He robbed my boy DC of a WGP, ditto Vettel on Mark. My life woudl be very different I am sure of DC and MW were WDCs :)
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
