yeh as above 22 is exactly flush.
I had 8.5" +22 on my ARX im pretty sure i ran a 245/45(or 40) on them and got away with a simple guard roll on the rear..
9.5+22 looks awesome! especially since the ARX has the "rub guards"
:yes: with Sunkist and 'tuckin7'.
I have 19x9.5 with +20 offset running 245/40/19 tyres on an RS replacing 18x8 +38 offset with 245/45/18 tyres.
Guards rolled and new BC BR coilovers bring them inside the guards.
Initially had just lowered springs all round but hung out the front guards by 15mm or so. The back almost flush. Photos to be uploaded soon.
AFAIK, the ARX has the wider guards so should fit fine, ie; +20 or +22 offset.
Lol I wonder how so we roll the plastic crap fender?
Hot blade and carefully cut a small amount off.. And roll the actual fender. Works a treat, and doesn't look like the fender was modded at all
Aaron why would you not go above +28? I'm running +37 with no scrubbing!
Because ideally not all of you are actually tracking the stageas, so a bit of looks(for some) may be the more preferred thing over wheels that aren't in with the 'flush' crowd. Just saying what can fit, and what it will take is all. I personally didnt like how sunken the +38 looked, especially that the rub guards make the guards look wider..
Opinions..
End up getting some 19x8.5 +17 with 245/40/19, on stock suspension they look just inline with the guard. But when I go over a big dip at speed the rear just touches the guard lol.
Would harder springs on the bc's reduce that from happening? Also by lowering the wheels will camber in a bit right?
And roughly how many cm is a good lowering height for the arx without risk destroying my spanking new blitz exhaust?
the stiffness may stop it from bouncing that low..
but if you wanted to lower the car, and have correct camber, you will need a roll.
can't remember the height, Daleo i think did a pretty good write up on measuring heights back in the day with BC coils.. have a search
For your viewing pleasure;
Ok, due to the number of people fitting these at the moment; I thought I'd supply my rough adjustment numbers for initial set up.
These numbers won't be ideal for everyone, but the aim is to have a ballpark setting to speed up the fitting process, as the fronts come set extremely low, and the rears rather high. You can then fine tune heights to suit your preference, or even go to corner weighting to acheive a perfect setup.
Front;
Free length of coilover assembly; 387mm from underside of top mount plate, to shoulder of lower mount (the part that makes contact with the forged mounting arm)
Spring length; 195mm from underside of top mount plate to upper spring collar (the part of the collar in contact with the spring and plastic washer)
This will give an approximate guard to hub centre measurement of 360mm
Rear;
Spring perch height; 45mm from the widest dia. of the machined perch to the outer spring collar (the part of the collar in contact with the spring and plastic washer)
The spring perch faces down; so the measurement will be taken from the highest part of the shoulder to the lowest flat surface of the lower spring collar.
You will still be using the rubber bumper from the spring cup in the lower control arm.
The reason I haven't included ground clearance measurements is depending on rim diameter, tyre profile, and bodywork heights; these measurements will vary wildly if you're running 17x7s with 215/5517, versus someone running 19x9.5s with 265/35/19 and so on.
My car doesn't scrape on very much at all and with 245/45/18's on 18x8 V35 rims; has about a 12mm gap between guard & tyre when looking in from the side of the car; which is about spot on for my eye.
Have fun guys, and feel free to add any measurements and set up tips for others to benefit from.
Cheers, Dale.
FYI; the last set if fitted (Rosella's M35) had shorter springs than mine.
They are now marked with a Blitz logo, and require at least another 10-15mm on the rear collars.
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
