Hey guys,
I'm at the point now where I want to connect some devices to my ECU. The devices require a splice in connection to the ECU harness (ignition, rpm signal etc).
Now before I go in there and splice in, stripping back the sheath and winding the wire around and soldering, i'm wondering is there a neater way to wire in this sort of stuff without effecting the factory loom? Are there breakout terminals that can go between the ECU connector and the wiring harness connector to provide wiring "terminals" to each output/input? Can you replace the ECU wiring section from a connector at some point along the line?
Thanks guys,
Regards, Kurt.
Apexi do an extension harness that sits between the ECU and the loom. If you really dont want to splice the factory loom then i think this is the best way that i know of.
http://www.ebay.com/itm/APEXI-ECU-EXTENSION-HARNESS-NISSAN-SKYLINE-R20-R25-R26-/280749102523
wish id seen them before i wired in my G4, but then again, once you go aftermarket ECU chances are you will never go back to factory anyway.
I once found some splicing terminals at Dick Smiths (IIRC) that basically create a "T" connection onto any given wire.
(have a look at the 3M catalogue for "3M Female Disconnects - T-Tap Nylon Insulated Self Stripping" - http://multimedia.3m.com/mws/mediawebserver?mwsId=SSSSSufSevTsZxtUnY_vM8tSevUqevTSevTSevTSeSSSSSS--&fn=03_Termnl_KitsTools_v03.pdf)
Thanks for the posts guys!
blind_elk, thanks yeah I've used those before, and probably would use them again if there was no other option. Last time i used them they didn't make much of a mess with the loom so they were a great option.
Since i'll be wanting to run a Nistune at this stage, i'll be only tapping into wires for various devices (Bee*R Limiter and at some stage, an MFD)
gotRICE? - That is exactly what I was after!! Thanks for finding it!
Your welcome.
If you get one, just double check every single wire and that it goes to its corresponding pin on the other end of the harness. I have heard of the odd one being put together wrong and causing headaches.
Although that was those green Hondata harnesses when they first came out.. still, good idea to check.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
