Hi everyone,
I have searched for threads all over google to try and find the answer to this. I already have an aftermarket boost gauge set up in my 33 gtst, however I am almost certain when I purchasing the car, which was most likely about a month ago that the factory boost gauge was "working". By working I mean that when I turn the ignition, the gauge will start up and sit at zero and move up and down when I am on or off boost. However when I am driving the gauge does not move what so ever but does move up to zero when I turn the ignition. It is if is the gauge has power but it is not sensing boost. Could the sensor have been removed when the aftermarket boost gauge was fitted? This is my first turbo car and I do have lack of knowledge, which I am working on :).
Thanks
Sean
Follow the factory black hose.
It should connect to the black box which is the factory boost sensor. When installing an aftermarket boost gauge, a T-piece is used in between. Check whats happening there.
If the black box is getting an ok vacuum/boost supply then it could be a dry joint on the plug inside of it. Try removing the lid of the boost sensor and check the soldering it could be black and dry. Run a soldering iron over it and remelt the solder.
Rekin, thank you so much that thin hose was my problem. It wasn't connected to the piece underneath the black box. I hadn't noticed this because when I had a quick look around, I saw that hose was just heading down but didn't realise it was detached.
Thanks anyway Tommy :)
no probs, glad to hear it was an easy fix.
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
