Hi John
I've meet you few times at UAS, John told me about this thread, will be good to see how this car progresses, subsribed
I'm a big fan of the blue front bar in the above video... Do you know who makes it?
It is a custom bar that was made by Phil Coles ( who drove the combined touring car ) and the guys at BSM for this car when it was still racing in IPRA
Marko... It's called a safety factor. The goal was to run about 400rwkw @ 20psi as a run in tune.
The car is getting completely rewired mid - late January and then I want to get it out for some practice runs...
your saftey factor results in 440kw...... F@$k'n AWESOME
Having gone through another few projects in the past and "trying" to keep control of the costs, my aim was to try and get about 400rwkw at 20psi as we think this should be "safe"... 440rwkw at about 23 psi is pretty good but I do not want to push the motor as it is a fresh rebuild.
I'll get it out for some private practice and get a few kms then we might look at whatever the restrictions are and then push a bit harder. The turbo should be good for around 900hp at the flywheel?
  • Like 1
Tune on BP98?
Its running Caltex e-flex E85 fuel but a lot of people I talk to are running the United E85 from Rozelle in Sydney... not sure if this is a better fuel? Anyone?
ATM I believe the tune is quite conservative running on the richer side and not too much timing...
Thanks for the thread John am enjoying it.
Great work
It will hopefully get more interesting once I get it out for a run.
Here is the plan from here:
1. Get the car rewired and recheck the tune at UAS.
2. Take the car out for some practice
3. Sort out suspension need front & rear adjustable control arms, tie rods etc... do roll centres and try and fit 295s under the guards. (The car ran 265s alround when it ran the 1:35 at 2010 time attack)
4. Get the car down to Tune house on the 4WD dyno for a higher power tune and to check 4WD operation
5. Try and make it to Nissan/Datsun Nationals
6. Aero... Replace rear wing and setup proper under tray
7. Practice, practice practice
8. Get to World Time Attack in October!
Oh... and try to lose 15kgs in between...
You should have no problem getting the 295s under the guards. I'm running 305x680x18 Pirelli slicks no problem.
What 4wd controller are you using?
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
