The cam covers are from an RB30 and seem up to the job.
Unfortunately Dale I don't have any photos of the aero on me. Might have to come see the car at World Time Attack :P
Hey guys once again I've been pretty slack and have not updated my build thread... ("Plan B" Another thread)
Been busy at work and trying to get the car ready...
John Boston will be doing a few sessions and I will be doing the rest... So the car will hopefully set some decent times and then ill have some fun!!
I will post up some more updates and photos over the next few days.
Edited by JohnGTR
Tunehouse have committed to assisting me to get te car ready and John Boston is helping with the setup so it has gone from a "Oh, Yeah lets just get the car out there and have some fun" to a "Let's try and get this sorted out properly" type attitide...
Still have a long todo list on the car... Here is what is happening:
- The fuel pump setup is being revised and we found that the foam in the tank was deteriorating (e85) and bloking one of the lift pumps. We also found the the primary (single) pump was locking up and failing. We had fuel pressure issues during the first test ewith the new box.
- After a weeks worth of emails and correspondents with the Precision Turbo guys I have ordered a new smaller turbo to try and give it a few more herbs down low. John Boston did not like the power out of the slower corners. The car made 500+ kw atw on low boost setting. Making power is not a problem !! The theory is, smaller turbo, faster spool, more power earlier in the rev range but then wind it up top and still make the power. We need more power to push the car through the air down the straight... 260 Km/h is not quick enough.
- Having a good close look over the Motec configs found some interesting settings which we need to sort out and a couple sensors are ot working properly.
- Need to secure front bumper and diffuser, dragging on the ground after 250 km/h and clean up aero.
These are the major things but I have a a lot of little things to sort out as well ...
I am hoping to merge this thread with my original thread (Plan B Track Toy) ...
Thanks Duncan, can you change the title to "R32 GTR getting ready for WTAC @ Tunehouse" ?
Actually John Boston never drove the car previously, he had a sister car which was well underdeveloped compared to this one. He drove it for the first time at SMP when we took it out for its first run with the Holinger...
Getting pretty eager to get it out there again !!
I know how a hub dyno works, you should be making peak torque at around 5000-5500rpm not 7500rpm. Something is causing you to lose a lot of mid range power?
PS. How do the RB20 Nics covers go with blow bye?
Why should you be making peak torque at 5000 - 5500rpm? I know this this would be better and we are looking to address this with a smaller turbo but the car just loves to make the power and torque up top with the current setup ...
RB30 covers seem to work fine and getting no blow by but do have a dry sump setup !!
It actually got tuned with e85, a bit more boost & timing all the usual stuff... Its not really being pushed but as per above posts its not making the power down low which is where its needed...see how we go with the new turbo!!
Edited by JohnGTR
Here is a video from the first test at SMP ... John Boston driving the car for the first time with the Holinger, this was his first lap at what he says was at 70%... We are trying to fastrack the development of the car and sort out all of the gremlins, having John help us with this is such a bonus...
On a engine like yours torque should peak around when full boost is first reached and then hold (maybe trailing off a little) until redline. The torque/power graph posted looked like boost was creeping throughout the the range... Have you got a boost plot?
Also they are RB20 NICS covers... RB30s are single cam engines
Correct... We will be looking at the wastegate spring and boost control to try sort this out ...
What new precision turbo will you now use to get power on sooner?
A smaller one than the 6768... Is that a good enough answer?
I've been in contact with the Precision guys and they made a recommendation but we have gone for a slightly different one and we've ordered it with two different exhaust housings so that we can play on the dyno.
Well actually no, as it didn't answer the question. But wish you well.
Well actually no, as it wasn't an answer. But wish you well.
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
