post-12712-0-62352600-1353974642_thumb.jpgpost-12712-0-38028200-1353974645_thumb.jpgpost-12712-0-43889200-1353974657_thumb.jpg
HKS hi power silent catback exhaust, 80mm, ran over 340RWKW.
Used, less than 2 years old
Suit 34GTR, fit perfect with rear diffuser, no droning and a nice note.
Replaced it because I went custom setup.
Will need 2 gaskets and hardware.
Price: $500 SOLD
Note pic is of dumps when just coated, they are matt black now after use.
R34GTR factory stainless steel dump pipes x2
Used in good nick, off a 99 vspec
Flow better than 32-33GTR cast dumps
I had them ceramicoated by Craved, includes factory head shields
Price: $250
Nismo 555cc injectors
Used, had them in my car for less that a year, suit All RB26.
pulled them out due to going to 1000cc
work fine, should get 350RWKW or so with 98 depending on pump and fuel pressure.
Price: $250 SOLD
Cam gears, adjustable. Possibly made by racepace, were on car when I bought it.
Used, from my 34, these are factory outer gears with an adjustable center.
Very durable, cost effective upgrade to suit 32, 33 34 GTR etc.
Price: $100
Located in Richmond, western Syd
PM if interested.
Pick up prefered, I can post smaller items via registered post
I'll take those Nismo injectors as spares (for a car that's coming) thanks Sean.
I'll pickup n pay on the 5th or the 8th if that's OK?
Kind Regards
  • 11 months later...
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
