  • Replies 161
Posted Images
Yeah... a 10cm distance :whistling:
Usually don't have someone hooking under the arms, just ready to assist with the bar shadowing it. When I used to do squats years ago in a supervised environment we were just instructed to drop them, never got assisted. Wrong or down to preference?
Although that was a while ago, could be mixing up the dropping with deadlifts. My memory is terrible.
Edited by JEPPE
down to preference i believe. i've read people say (actually over in the gym thread here haha) that if you're going on heavy weights (where you might have difficulty) then don't use the collars, so that if you really are in trouble then just tip over and drop off the weights. remember that the bar will swing up though haha
^^^ That's only with Benching.
If you're squatting by yourself, you really should be doing it in a power cage with the safety bars there to prevent you crushing yourself or damaging the bar.
You can't spot a squat by shadowing the bar.
unless you want to hurt yourself and the lifter.
Edited by TTT
I suppose it wasn't spotting as much as it was assisting, I get what you mean though.
Have seen people using the cages before, sometimes they seem to do it at obscure angles though. Is it meant to be used as if squatting without a cage?
in a proper comp, you have spotters on either side of the bar too.
Their job is to help lift the bar.
the spotter behind is there to keep the lifter from falling or folding over etc.
Charlie - the safety bars can be removed.
you can do everything in there as the pin height where you put the bar has many heights.
Most of those cages will also have chin up handles on the top and some have dipping bars on the side.
That's why they are great for home gyms.
you get a power cage, a bench, barbell and weights and you can do 99% of what you need.
the best technique in heavy squatting is to have no spotter behind you, and if you fail you just throw the bar behind you.
It's the safest and easiest, and means you don't need a power rack or a spotter to squat to failure.
I honestly can't see how it's possible to get the bar to fall BEHIND you on a squat that you failed due to being unable to lift it.
If you squat high bar and can keep your torso upright, it will be easier to dump the bar behind you.
Low bar and wider stance has you leaning forward more.
That would be hard to dump the bar behind you.
Also depends where in the lift you fail.
If your hips raise faster than your torso (bad form or fatigue etc etc) you'll end up in a good morning type position and you won't be able to dump the bar behind.
Yeah I was thinking this.
Plus I'm in the mindset of low bar anyway, high bar is uncomfortable as all shit for me.
let go of the bar and move forward. Maybe easier with a high bar upright squat but unless you are good morning the squat for some reason it's easy to do with a low bar squat too
Or you could squat in a rack/cage that has safety bars and ass to ground it onto the bars if you can't lift it...
I hate squatting in a cage, everything is so close and i get a bit claustrophobic.
Outside is fine, it shouldn't be that often that you are failing on a squat in training anyway
provided you have bumper plates and a floor that is okay to drop weight on
when at commercial style gyms I squat with no spotter and no safety bars... then you have no choice but to make the lift... you'd be amazed how a bit of panic/fear can help you out of the hole lol (don't do this with 1RM attempts obviously)
I know, that's why i never squat with spotters or a rack.
I guess if you can't drop the weights then use a rack i guess. Spotters are useless imo for squatting when training
Markos posted this on another forum... a must read for girls (make sure you read the last couple of pages)
http://startingstrength.com/articles/training_perspective_gillian.pdf
"In Mark Rippetoe’s words, “Your appearance when fit is almost entirely a result of your genetics,
which are expressed at your best only when your training level is at its highest, and this level is only
obtainable from a program based on an improvement in your performance, in the gym or on the
field. And the best improvements in the gym occur when participating in a program that looks more
like performance athletics – the kind of training done by competitive athletes – than one that looks
like waving your arms and legs around on a machine or slowly rolling around on the floor” (Strong
Enough?, p118)."
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
