Hey i am wrecking this R33 gtst Coupe, i also have some R33 sedan parts and R34 as well left over from the other wrecks prices as listed or PM or post please
Rb25det Neo motor $1400 PENDING
RB25de NEO gearbox $650
RB25det Gearbox $1200
RB25DE Neo motor $500 SOLD
RB25det Neo Autobox $100 SOLD
RB25det S2 turbo $250
GTST brake setup calipers lines hubs etc $800
R33 rear cradle $100
R34 rear crade $120
R33 GTST diff $200
R33 crossmember $75
R33 GTST engine mounts $100
R34 GTR fuel pump and cradle $150
R33 GTST stock suspension springs and shocks F&R setup $200
R33 rear lower control arms $75 each
Front lower control arms $75 each
camber / traction rods $10 each
Sway bars front and rear $20 each
R33 gts4 front cross member GTR? $50
R33 gts4 4.3 diff $200
R33 gts4 tail shaft GTR etc $100
R33 gts4 calipers all 4 $50
R33 GTS4 rear hubs 4 stud $50
R33 Drivers door Black $100
R33 door drivers side KR4 silver $100
1 drivers side M spec side skirt $50
R33 boot lid $125
S2 wing $50
Rear tail lights $50 each
Drivers side rear quater panel $100
Rear reo bar $25
Rear bar SOLD
Door handles KR4 silver $25 each
Brake booster $50
BM44 ABS cyl $50
R33 S2 seats with rails $150 pair
R33 S2 seats with rails worn drivers right bolster $100 pair
R33 S2 rear seats $100
R33 S2 carpet $100
R33 S2 dash surround $100
R33 GTST S2 dash $100
R33 centre console $50
R33 Space saver as new X2 $50 each
R33 door trims $50
Passenger window switch $50
R33 S2 climate control $35
Fuel lid $50
R33 heater box $50
R34 climate control centre $150
r34 gtt AUTO CLUSTER $100
R34 sedan doors $100 each
R34 dash glovebox etc $200
R34 heater box $50
R34 front bar $150
R34 front indicators orange $20 each
R34 3" exhaust system Rienhard $400
R34 brake setup calipers slotted rotors F&R and hubs $900
R34 ignition barrel and key $100
R33 sedan S2
Doors $100 each
centre garnish rear $80
Carpet $100
S2 airbag steering wheel $100
ABS module $50
NAVAN auto shifter (suit all R33's) $50
R33 gtst fuel tank $50
HKS 4" mushroom filter pod no element filter new ones arnt that expensive $100 never seen one this big??
HKS mushroom filter and element 3" $50
Few other R34 parts from a sedan if your interested post up and i'll see if i have it i have most of the inside plastics but shell etc are all gone only have doors left as panels
also have R33 S2 sedan other parts just ask i might have some
PM post or call 0422646961
DO NOT BUMP MY OLD WRECKING THREADS PLEASE EVERYTHING IS HERE IN THIS THREAD
https://www.sau.com.au/forums/topic/414602-edited-admin/
Hey mate, just wondering if you've still got a few things:
- R33 S2 door trims
- R33 steering column plastic surround with the ignition barrel plastic
- R33 drivers side window switch (or does it come with the door trims?)
And if possibly, could I get pics of the door trims as I'm after mint condition ones.
If you're still got any of it, best price posted to Meadows, 5201 SA. Cheers.
Edited by brentos_mentos
https://www.sau.com.au/forums/topic/414602-edited-admin/#findComment-6734942
Hey I still have all except for the switches they have been sold I picked up another R33 shell so I have a few more bits and pieces now as well
Have since sold
rb25 det neo
Rb25det
R33 s1 headlights
R33 brake setup
310mm rotors and pads
https://www.sau.com.au/forums/topic/414602-edited-admin/#findComment-6739278
  • 4 weeks later...
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
