Yeah spoke to crd who said they could port them. They did want a fair bit more than uas. Is there anyone else who can extrude hone them and port match them?
How much power are you after?
Just so this post does not become another useless post found when searching for an answer to this question, from my ringing around this is what i found.Unique autosport no longer offer this service.CRD will port your turbo manifolds though were fairly up there with their price.The final one, and the business i chose to go with was pro fabrication race engineering. I was not sure if this was a service that brad offered, so i made the call and was pleasantly surprised with the level of professionalism and the price aswell as the enthusiasm to help. This is something i have found lacking in some businesses lately so it was good to see from a customers point of view. This is the first transaction i have had with pfre so it may be common knowledge but as a result it is the first of many to come as i hope to use their services for many more areas of my build
Adam
Adam
Bang on mate! I have nothing but a good experience with Brad from Pro fab..
Hes very keen to help, does a good job and finishes it on time.. Not to mention his pricing is very reasonable!
Even went beyond what was required for the job
I made just short of 400rwkw with T517Z's on pump fuel and stock 26.... manifolds were stock, not ported. in 2006.
Saying that, I'd just get them match ported and coated... I wouldn't worry about extrude honing. The gain versus cost is all wrong.
Spend that money on a better exhaust or intake/cooler pipes or cams etc.
As a side point, i have some r34GTR N1 manifolds... they are a different casting and different material.
Cheers
Justin
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
