G'day guys i finally bought a skyline but its having a little issue i was wondering if anyone can help me.
1st thing: when i put the aircon on the revs lower 400rpm and stay low. Is it the FICD?
2nd thing and i think there related: any load i put on the car (lights,steering ect) revs drop and stay low,if i just slightly open the throttle just a teeny bit and find the right spot,(might take a min or 2) it will lower revs bout 300rpm and idle fluctuates.but after i find the spot and i opening her up a little bit more it dissapears.
it only does in the one spot when opening the throttle slightly.
Is the AAC and FICD blocked or sticking?
And are they both in the same housing at the rear of the manifold?
Its giving me the shits as soon as i drive off clutch out,slight throttle it fluctuates and carries on.
any help guys would be appreciated.
Ok i took it off and it seemed not that dirty and nothing was clogging the air bypass were the screw goes into.
also turned the a/c on and unplugged the FICD and i could hear it clicking...but no change in idle? It should increase RPM
That part could be clogged? or need replacing?
I also just noticed the fluctuation (maybe misfire) it happens more when warming up but decreases when warm but its still there.
Maybe TPS?
Maybe TPS?
if its a misfire then its almost certainly your coilpacks.Have you replaced them? Gapping plugs to 0.8 and splitfires fixed my misfire problem , revs would drop down with noticeable misfire and jerk at wide open throttle.
I gapped the plugs yesty heat rand 7 good plugs,fouled from slightly rich tune.
and there brand new spitfire coil packs.
WOT no missfire,
It seems like a apparent miss or hunt when i just touch the throttle and i have to hold it at right spot for it to do it im talking like .5-1mm
of throttle movement and it happens.
if i
I PM'd the video it would let me upload it otherwise. its cold first off then its warm n sits just below 1000rpm then when i touch it its flickeres up and and down
cant see the video
upload it on youtube or on www.mediafire.com and give me the link
Yes and gapped to .8 as everyone does, in this forum anyway. I cleaned the AAC unit and adjusted my tps and cleaned my maf.
Problem now instead of fulcrum ting (hunting) if I put any load on the engine it will drop idle and carry one untill I open the throttle up
that sounds like a deeper issue
the only things that would cause that , that i know off are all the things you've already cleaned & checked. tps , maf , splitfires & plugs...
coils and plugs are the number one issue for this....
where are you located? My mechanic Paden from Unique Automotive (in villawood sydney) is a genius and Im willing to bet he can diagnose this by just listening to it.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
